Old 04-18-2011, 05:04 PM   #1
Atridox's Avatar
Engine: Gasoline
power steering pump
My 1987 Chev C60 w/ Chevy 350 has a leaky power steering pump. Apparently, the power steering pump for this was a bit unique. Chev discontinued it and I have checked with numerous salvage yards and can not seem to find one. Is there somewhere I can send the pump to have it rebuilt (if that is even possible)?
Atridox is offline   Reply With Quote
Old 04-18-2011, 08:35 PM   #2
Engine: DTA360
Rated Cap: 16
Re: power steering pump
Post up some pics of it and any numbers you can find on it...
dirtygoat is offline   Reply With Quote
Old 04-18-2011, 10:33 PM   #3
Atridox's Avatar
Engine: Gasoline
Here is a link to a pic of the ps pump
http://db.tt/kVbnLyv
Old 04-18-2011, 11:02 PM   #4
otto802's Avatar
Year: 1987
Coachwork: Ward
Chassis: Volunteer 6-Window
Engine: Propane
Bummer, I think I have the same pump and it's leaking as well. My bus is also a 1987 C60.
otto802 is offline   Reply With Quote
Old 04-19-2011, 08:17 AM   #5
Have you tried removing it and taking it some place like NAPA? Often times there are equivalent parts that can be sourced and having the part in hand makes it easier to identify. Also, a parts place might be able to recommend a rebuild shop.
I think my '91 gasser has the same pump. I suspect a lot of the old farm trucks around here have one quite similar. Unfortunately, my '91 is spoken for after I'm done with it, so I can't offer parts.
Good luck,
jim
baadpuppy is offline   Reply With Quote
Old 04-19-2011, 06:23 PM   #6
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I think you'll find that the only thing unique about it is that extra reservoir on top. Chevy used that basic pump for many years on pretty much everything. I would think you would be able to find something with a similar bolt pattern. If I remember correctly some had a reservoir that was separate with hoses going to it. Where exactly is it leaking, the large "tin can" has an o-ring where it meets the main cast part right behind the pulley. I think everything is held together by the screw in fittings at the back, which also have o-rings. We used to fix them all the time.
The nice thing about "old things" is that they were made to take apart and be fixed.
Old 04-19-2011, 08:28 PM   #7
Engine: DTA360
Rated Cap: 16
X2... Looks like a remote reservoir GM pump to me... Check out 1 ton Chevy's from the same era...
Old 04-21-2011, 12:18 PM   #8
otto802's Avatar
Year: 1987
Coachwork: Ward
Engine: Propane
Maybe this seal kit will work? http://www.carpartsdiscount.com/auto...ml?3593=147173
1991 366 Chevy power steering pump GreyEagle Mechanical and Drivetrains 0 07-20-2011 10:49 AM
366 power steering pump TfallsTrio Mechanical and Drivetrains 6 06-15-2011 04:15 PM
Need help with Power Steering kirkndopp Conversion General Discussions 2 07-07-2010 10:32 PM
Need Power Steering Pump for 1987 Ford 429 Trdoc1949 Classifieds | Buy, Sell, Swap 1 05-18-2010 12:37 PM
Power steering pump neeed KaptnKAOS Classifieds | Buy, Sell, Swap 0 09-03-2007 12:10 AM
