10-13-2011, 08:15 PM
#21
Rated Cap: 89
Re: 1996 Ford 7.3L gas E350 Eldorado - Aerotech
Originally Posted by bullwhacker
Water tanks? Hmmm...
Have you thought of using heavy wall PVC pipe? 6 to 8 to 12 in diameter?
You may be surprised at how much pipe you would need to get a decent capacity.
This is a good tank Calculator (I saved it to my desktop and it still works even when off line). For a round pipe use the "flat bottom" under tank type (think vertical rather than horizontal) and type in the "diameter" and "height" (for the pipe length).
JC Whitney has some decently priced Valterra tanks (ABS) that you can glue fittings into the sides, top, bottom. Plus they can be repaired fairly easily unlike poly tanks normally sold for RVs. We have bought two of these tanks (30 gallon will be the fresh tank in the bus...the 21 gallon is the fresh tank in the Class C). We like them. In the future, I plan on adding another 30 gallon tank (or two) in parallel with the 30 gallon tank we have now. I will also add corresponding ABS tanks to the grey tank we have (used 42 gallon poly tank from an RV) when I up the fresh water capacity. I'm not a big fan of poly tanks. Especially after we removed the Class C's poly fresh tank to repair it. It fell apart from age(?). The ABS tank was easy to install and install fittings.
10-13-2011, 09:04 PM
#22
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
4" pvc 10' long is 7 gallons, just in case your wondering
10-13-2011, 09:09 PM
#23
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Originally Posted by Tango
Hey Ptooti --- you might look into a "jacknife" bed that folds into a sofa when not in use. With any Shorty you have to try and think "multifunction, collapsible, hide-a-way" or you run out of space really fast. Just a thought.
"Think submarine" was our moto buliding the bus.
Heres a bed idea. We have benches with storage underneath.
The silver bars you see in front are squares the swing out.
A piece of thick wall 1" sq. rests on top of the squares on the long span.
The wood over the bench has a 2nd piece hinged that folds down. We then set up a full sized air matress.
There is a apx. 8" from the edge of the bed to the wall -so if i had to get to the back i could-and a little room to get to the bathroom. I actually have 1 more piece now-another hinge has a 8" section that holds the air matress from "muffin topping' + hanging over the side. (picture the side of a waterbed.)
Set up time is maybe 5 minutes including blowing up the air matress.
10-14-2011, 03:32 PM
#24
A cylinder 12" x 72" is only 4.7cf and will hold 35.2 US gallons. Still great for the price but nowhere near 70 or 80.
Volume of a cylinder = r squared x pi (3.14) = area x length.
10-14-2011, 06:42 PM
#25
Coachwork: Ford Eldorado / Aerotech
Chassis: E350
Engine: Ford 7.3 Gasoline
Rated Cap: 11
Wow thanks for all the great info and pics you guys are a wealth of information! has anyone ever considered one of these propane tankless water heaters? http://www.ebay.ca/itm/Marey-Portabl...ht_2710wt_1330 I was thinking of mounting one on the back of the bus outside somehow and use it to feed my hot water tap. And what are the laws for propane tank location in my old bus the tank had a vertical mount up high on the back of the bus just wondering if that is still allowed? I had just a 20lb tank before
If the women don't find you handsome they should at least find you handy. ~ Red Green
10-15-2011, 10:10 AM
#26
Tankless, on-demand propane water heaters are great. They use about 25-30% less energy and provide continuous hot water for as long as they have a supply of fuel.
However...be advised that there is currently only one unit on the market approved for use in RV's (Girard). All of the other makers have specific language (legaleese) stating that their products are not for RV use. Several make reference in their copy that they are " great for small cabins, RV's and marine applications", then turn right around and state otherwise in the small print. Can be very misleading if not illegal. Biggest considerations are whether they are for "indoor" or "outdoor" use due to CO2 buildup but the main concern is how the gas lines are configured and can handle vibration. Here again, read the fine print if you want to avoid a fiery situation that you will have no legal recourse on.
There are also electric, tankless water heaters available, but the only ones that provide an adequate temperature rise require 240 (and more) volts at high amperage and some even require 3-phase electric which makes them pretty useless on board an RV.
I will likely go with a small propane tankless myself, but will have to do still more homework before I decide which one. I would strongly suggest everyone else do the same if that's the route you choose to go as there are numerous, very real differences in the available brands and models.
Below is a good start. And keep in mind that anything less than about a 70-75 degree rise in water temps will severely limit when and where you will actually have "hot" water.
http://en.wikipedia.org/wiki/Water_heating
10-15-2011, 12:25 PM
#27
Need to correct the above..."PrecisionTemp" also makes a tankless water heater that is for use in RV's. Only catch is they run a cool Grand ($1000 bucks).
10-15-2011, 01:02 PM
#28
Rated Cap: 89
.., However...be advised that there is currently only one unit on the market approved for use in RV's (Girard). All of the other makers have specific language (legaleese) stating that their products are not for RV use. Several make reference in their copy that they are "great for small cabins, RV's and marine applications",
Way back when we were still on working on the Eagle conversion (trying to get rid of all the rust first), I corresponded with that folks who built the tankless water heater I was interested in (don't remember the make but it was a TN company). They told me that it cost too much money and time to get "approved" for such a tiny market (RV) and if they did get approved, they would then have to court the RV manufacturers to get their stuff into the RVs. That said, the Pres, VP, most of the engineers and a good pile of the workers loved RVing. And they had installed the tankless water heaters in their units (they pulled the RVs into the factory). I was told to make sure I vented the tankless outside. Then an engineer sent me diagrams on how he installed his tankless water heater in the bay of his RV. Included was a disclaimer that the company lawyer said had to be attached since they were not "approved" for installation in a mobile unit. He had to include it even though he sent the info via his private e-mail.
As for "approved" uses... The people on this forum are using former school buses in an "unapproved" manner. They are using many materials in an "unapproved" manner.
BTW, there are now TWO Tankless RV units. One predates Girard by many years. The RV-500 has been on the market for several years now.
ballpark $1K
http://www.gaswaterheaters.com/boats...V500/index.htm
http://www.vintagetrailersupply.com/..._p/vts-840.htm
http://www.globaltowne.com/product_i...products_id/53
A Thread on the Girard Tankless. You will want to read ALL of it. Most of the stuff applies to ANY tankless. We will install an Eccotemp LV12 ($293). We have the Eccotemp LV5 on the food cart (pumped with Shurflo 2088 40PSI 2.8 GPM pump... placed inside, vented out, burner kicks on only with full water flow... not what we want for "home" use). The LV12 is bigger and will be placed under our kitchen sink and vented outside. The inlet water and fresh tank will be directly under the kitchen are and in a heated box. Our water set up will always draw from the fresh holding tank. The fresh water will come in from the city water hookup, pass thru two filters and a water softener before entering the fresh tank thru a Dial Mfg. 4153 Float Valve. When the water level is down, the valve opens. When the tank is full, the float closes the valve. No more standing around waiting for the tank to fill and water pour out of the over flow. Since our filters knock the water flow down so much, this is our best solution. We also figure that when we are traveling, we will just pull into a campground every couple of days --- dump black/grey waste tanks, fill up the fresh water overnight. The softener will keep the mineral build up on the tankless water heater, etc to a minimum. Mineral build up is deadly to any water heater but seems to be worse for the tankless units.
A point to take into account is how you will use your bus. In many campgrounds, electric is metered or included in the site rent. Often AC is cheaper than LP. Boondocking/wallydocking means you rely on LP more but you may be limited in your water usage. Altitude may need to be factored in as well. The thread link above has some info on these points. No matter what type or brand of water heater you chose, I would suggest you read it. How you will use your bus and your water requirements can only be taken into account by you. Make sure you discuss water use with your mate/partner. This is not a good subject to have a misunderstanding.
We have an Atwood AC/LP 6 gallon water heater in our Class C. We bought the water heater in 2007 and have yet to operate it on LP. It works well, recovers fast on AC. By the time one person gets showered/hair shampooed (and conditioned/rinsed) the tank is running out of hot water. It does recover by the time I get dried/dressed. But David doesn't take as long or hot a shower as I do. So we allow a few extra minutes to heat back up when my daughter takes a shower after me (or I take one after her). It does take a bit of learning if you are a "long, hot, leisurely shower" type person. It costs quite a bit more than the LV-12 back then and the LV-12 is about half the price of a new Atwood today. I do love a long hot shower in the winter. Thus my fascination with the tankless water heaters. I love the idea that I could take a 2 hour shower.
10-15-2011, 05:43 PM
#29
Excellent thread with a lot of useful info. One of the great things about this forum is the shared research & real world experience. Thanks to all who make it what it is.
11-23-2011, 12:59 AM
#30
Chassis: E350
Rated Cap: 11
I have shut down for the winter it's too cold here now to work on the bus anymore anyway I managed to get my wheel simulators on and they add some bling!
11-23-2011, 08:38 AM
#31
looks pretty smart! Im thinking wheel simulators is the way to go.. i might as well get a new set.. missing one and the ones i have are all banged up..
11-23-2011, 04:44 PM
#32
Chassis: E350
Rated Cap: 11
I got mine off ebay the hub cap king or something like that 200 bucks shipped to Canada the guy was excellent to deal with and they are a quality product Top-rated
sellers name is the_hubcap_king
http://www.ebay.ca/itm/WHEEL-SIMULAT...#ht_849wt_1057
05-21-2012, 11:41 PM
#33
Chassis: E350
Rated Cap: 11
Added Screens to my bus
Okay after much thought I managed to come up with this and did all 10 of the windows on my bus application is easy the first window took about 15 mins to figure out a plan then after that about 5 mins per window.
The screen is on the inside so when the windows are closed for travel mode they will be protected.
I used 1/2 foam backer rod $3
screen frame kit with spline $10
fiberglass screen $7
I cut the screen frame to fit into the channel snugly to run vertical between top and bottom channel
then cut the screen larger than the window
jammed the screen in place using the 1/2 foam backer rod as a spline in the channel around the upper curve and a piece along the bottom
then used the spline that came with the frame kit to secure the screen into the vertical screen frame
then trimmed off all the excess screen.
Jabbing the backer rod into the channel to hold the screen
picture below the excess screen is ready to be trimmed off
Finished!
08-26-2012, 04:17 PM
#34
Chassis: E350
Rated Cap: 11
Re: PTooTi's 1996 Ford 7.3L gas E350 Eldorado - Aerotech
Hi Guys sorry for not posting all summer we have been tied up with other priorities and basically procrastinating!
Ok I need to get my water tank and electrical installed what is choking me is I actually have to cut a hole in the wall for the filler hose for the water tank can anyone show me a pic of what to expect or how to do it I'm afraid of hitting wires or something?
whats inside the walls of these units?
08-26-2012, 04:33 PM
#35
since you dont have a metal skoolie, i cant help much, but i never worry about cutting a hole that size in a wall because by just cutting the exterior opening, if there are any wires you cut, you can just splice them. One thing you want to miss is the vertical support channels that go up to the roof, so you should be able to look on the inside wall or the exterior wall (not on the fiberglass one the one i have seen) to see attaching points. hope this helps some, rich
08-26-2012, 10:34 PM
#36
Rated Cap: 19
My 2000 Aerotech has the fiberglass body and I've had no problems cutting or drilling through. I just used a hole saw for the round holes and a sabre saw for the larger holes. All the wiring in mine ran behind the fiberglass trim panels inside the bus. There were a ton of wires running down the passenger side and across the back up where the wall meets the roof. A bunch more ran down both of the back corners going to the rear lights and a few wires ran down near the floor on both sides going to the midship side marker lights. The light in the center of the back wall had it's wires running across the floor then vertically up to the light.
In general, if you avoid the corners you'll be in good shape. Mine has some plywood reinforcing between the inner and outer main body panels where the chair rails were attached. Other than that the glass body is easy to drill or cut. Aside from the chair rails I haven't found any steel supports at all.
08-26-2012, 10:46 PM
#37
Rated Cap: 19
Here's a shot of mine with the trim panels partially removed.
08-27-2012, 09:22 AM
#38
Chassis: E350
Rated Cap: 11
awesome Roach that is great thanks so much! you have restored my confidence!
08-27-2012, 07:53 PM
#39
Coachwork: Champion
Chassis: Ford e-450
Yea-i've blasted holes thru the walls on a moments notice-no big thing. All my wires run down both sides above the windows. Only place they run vertical is behind the driver.
Look out for the beams + poke away the spray foam insulation + your there.
08-28-2012, 02:23 PM
#40
so directly under a window should be fine?
