06-26-2011, 07:00 PM
#81
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
cut hole, ran battery cables and installed batteries, and viola, it cranked....yipeeeeeee
now have to install genny and run more wires
07-09-2011, 06:02 PM
#82
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
one of the hardest things I have done is to figure out where to drill a hole in the floor without hitting a seam, thanks for the nephew, hes real little for 15, we got er done
07-18-2011, 08:23 PM
#83
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
started hooking up the WFCO 55amp power station today. lots of fun. maybe by tomorrow I will have it done, then install the Onan and hook it up
07-20-2011, 07:58 AM
#84
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
go the wires hooked up to power station, drilled holes for switches in custom dash, all coming together all of a sudden
07-20-2011, 06:54 PM
#85
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
yeah, it seems that way. Just got thru hooking up wires and such to get ready to install dash. I have to pick up 2 new switches for the wipers, get them and I can install the dash, then install the genny, hope it cranks, hadnt been running for a few months, wish me luck. Actually gonna give it a dry run outside the box first. Thanks for the replies, seems like only a couple people have been watching my thread, tks again. SEC media days started today I think.......
07-20-2011, 08:28 PM
#86
Re: Putter's Bus
On your genny your need to start it about once a month and run it UNDER LOAD for about 20-30 minutes....
starting the genny and not putting it under load will not do anything for the generator.
The biggest problems with generators is lack of use.... at least 50% load during to make it work good.....
Good luck with your genny and your bus, looking good..
GreyEagle
Roll - On...
07-20-2011, 09:05 PM
#87
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
tks greyeagle, once I install it I will use it all the time, just had a hard time getting everything done to install it. My welder never did show up. I bolted it to the bus
07-21-2011, 08:20 AM
#88
Re: Putter's Bus
Converting a bus to a motorhome is not an easy task.... It's long hard work and murphy is always lurking in the background.
One job at a time. you'll get there just not overnight.
PS find you a welder, do not leave it just bolted on.... just food for thought
GreyEagle
Roll - On...
07-24-2011, 09:15 PM
#89
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
well I got all the warning lights hooked up and working. hooked up the wipers also, just left the other power wire unhooked (see my thread in conversion) and the overhead lights as well. Tried starting it up and I think my starter is going out. Just my damn luck. Its been dragging for a while, crank it once and a while ya know.
07-24-2011, 09:26 PM
#90
Engine: 3208 na boat anchor
Re: Putter's Bus
08-14-2011, 08:39 PM
#91
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
Painting the bus is gonna be a pain in the butt, wow. kinda got started with some stuff, its gonna suck.....
08-15-2011, 11:43 AM
#92
Rated Cap: 89
Re: Putter's Bus
I'm skipping the primer except for the aluminum panels where the windows were. The bare metal gets Aluminum primer. The paint I'm using seems to be covering well and I am hitting any rough spots with some fine sandpaper as I go (I'm using Deglosser first). I have the front complete (including the bumper) and am partway done with the drivers side. I spent most of one day just pulling that curve out of the bottom rub rail under the drivers window... But it's ALMOST straight. Looks like the rest. I love my bar clamps! Couldn't paint that section until I got it pulled out. But now I'm out of paint! And my roller/paint brush keeps drying out in the heat. I have discovered that I can paint from 9:30 (when I get dropped off at the bus) until about Noon. After that, everything is drying too fast. I keep thinning paint and painting bugs... I have several entombed in the roof coating!
08-15-2011, 09:37 PM
#93
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
picked up sandpaper, primer, and paint, lets the fun begin........
08-15-2011, 09:47 PM
#94
Rated Cap: 89
Re: Putter's Bus
You forgot the fly swatter!
08-15-2011, 10:06 PM
#95
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
dont have alot of flies here, at least not now. But when I am running shrimp, thats a different story, cause I have to eat some of them
08-16-2011, 12:00 PM
#96
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
aaaaaaaaaaaarrrrrrrrrrrrrrgggggggggggggg
08-16-2011, 09:00 PM
#97
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
sanded, and put 2 coats on part of bus, gonna sand again and put 3rd coat on in the am, hope it ends up ok, or I am gonna "bam"
08-22-2011, 09:12 PM
#98
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
paint looked like crap, dont know if its too hot or I just cant freaking paint. I have another plan, lets see how that goes... ON the starter issue, guess what? A 1989 7.3 has the same starter as a 1983 6.9, and I just happen to have one available, sweet
08-23-2011, 02:16 PM
#99
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
I sanded after 2 coats, then applied, it looks like it streaked, I think I will prime with this paint and then try to can the final coat. It will be a different color but it will look smoother I believe, time and money will tell......
08-25-2011, 07:23 PM
#100
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Putter's Bus
after further thought, I have ordered the paint to paint the bus the way I want, I saw where it cost someone 1k for a paint job, so the hammered paint from rustoleum will do. I started the rub rails first, mistake, so now I will wait on the deep blue. This paint covers alot of mistakes, it really looks good though.
