Old 06-01-2017, 09:54 PM   #1
Quieting the Ford 7.3 Powerstroke
Looking to quiet down the diesel engine on my airporter style shuttle bus a 1999 E450. The two areas esp want to quiet is the engine dog house and the hood. Instead of just recommending dynamat, please indicate what you HAVE DONE AND WHAT YOU USE? If just offering opinion, then indicate that. We all know what products are out there such as dynamat, but am interested about your EXPERIENCE and advice. However glad to have your opinion too, just indicate if you are drawing upon experience or advice? thanks
Bluespoet is offline   Reply With Quote
Old 06-01-2017, 10:14 PM   #2
roach711's Avatar
Rated Cap: 19
Check the donut seals on your up pipes. They are known to leak both exhaust and noise.
I put two layers of Peel & Seal on the floor around the engine cover and that made a noticeable difference in the racket.
At highway speeds wind is the biggest noise for us.
Liberal use of cloth and carpeting inside the bus will dampen noise.
The Roach Motel
Old 06-01-2017, 11:04 PM   #3
That is a great idea, the thing with peel and stick is that some love it and others hate it, but makes me wonder if those that hate it work for companies like Dynamat which lose alot of business to peel and stick. Putting down two layers would be easy and inexpensive. What ever I do, I hope it makes a difference.
Old 06-02-2017, 01:30 AM   #4
Robin97396's Avatar
Have you used one of the oil treatments? Those can reduce noise and heat a little. Every little bit helps.
Robin
Nobody's Business
Old 06-02-2017, 05:58 AM   #5
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I have installed many many sq feet of Dynamat at work. Its good stuff but expensive. Go on Amazon + look up other similar products. We found one that was less than 1/2 the price. (Turns out its made in Russia. )
I'll agree that wind noise is the most noticable going down the road.
Or you can run the engine on WVO-that quiets it a bunch.
Old 06-02-2017, 06:13 AM   #6
Rockwool is suppose to have a product that is 1.5" thick that might sound proof the firewall. I have used the thicker insulation for sound proofing risers for stage performances. Worked great and was fire proof.
Tootalltechie is offline   Reply With Quote
Old 06-02-2017, 06:18 AM   #7
ECCB used hotshot's secret oil treatment on his T-444E (7.3) and says it runs quieter.. im going to add it to mine as well.. (doing it at same time im changing my transmission)
