Old 05-13-2012, 05:06 PM   #1
Rear bedroom "U" Cut plywood How?
Im ready to put in my rear "Birth" Master bedroom.
How do you put those "U" plywood cuts to separate the areas?
Should I make cardboard templates then have my contractor cut the wood?
And it screws to the ceiling but wont penetrate into the actual roof?
Then brace the bottom to the floor by screwing from the underside?
Help, as this is a one shot deal, I either do it correct or blow my $1000 floor and end up with water leaks.
Thanks!!!!
Jaybus is offline   Reply With Quote
Old 05-13-2012, 07:28 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Rear bedroom "U" Cut plywood How?
What?
I know I just woke up from my nap and am a bit "fuzzy" but I am lost. I get up at 3AM to go to work... I have learned to take naps in order to appear to have a normal waking life even though I got to bed at 9AM at the latest. Lots of things don't make much sense to me anymore.
What is a Birth bedroom? Someplace to have babies?
Why do you have "U" cuts in the plywood?
Why are you attaching your bed to the ceiling? We attached ours to the floor.
I am sooooo confused.
Fulltime since 2006
Old 05-13-2012, 10:00 PM   #3
Lorna, nap time! It all makes sense
Old 05-14-2012, 10:24 AM   #4
yeha.. as posted before, you take cardboard (or maybe heavy paper for a starter) and make a cardboard template the exact curvature of your wall.. you gotta do the side and the ceiling in one piece of cardboard - or glue them up together. anyways ya gotta have a template that is an exact for for half of the bus, and you gotta check it on both sides...
you can then make the plywood cuts from that template, and to get an exact plywood fit, you take your 40 or so grit grinder and make the plywood fit exact if you wish. you might not be that picky if you are planning to calk the seam...
you can screw in plywood strips 3/4 thick x 2 inches wide with serf cuts about half an inch apart to make the curve section - this is screwed into the ceiling where your plywood wall screws to.. just dont use screws long enough to go through the main roof... try something like 1 1/4 ones.. drywall screws will screw through the inside bus roof without using a drill to predrill the holes... its like 24 ga - pretty light.. always predrill all your wood, though so it won't split.
ya can also use screws to the floor as well, but the floor is 18 or so ga, and has to be pedrilled unless you use those heavy metal self tappers. when drilling the floor, dont use real long screws either as ya got fuel, air, elect, lines under it.... you screw down... not under the bus upwards...
have fun..
Old 05-15-2012, 01:04 AM   #5
Engine: DTA360
Rated Cap: 16
I'm with ya Lorna, It confused me as well...
dirtygoat is offline   Reply With Quote
Old 05-15-2012, 01:05 AM   #6
Engine: DTA360
Rated Cap: 16
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 12:57 PM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 01:37 PM
up for auction!! 1972 GMC "New Look" "Fishbowl" Coachbus35ft Stuff Classifieds | Buy, Sell, Swap 0 01-18-2011 11:39 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 08:02 AM
"standard" plywood under rubber floor? NewSkewlHauler Conversion General Discussions 2 01-24-2010 08:18 AM
