Welcome !
Cool little bus !
Those that have removed the heaters usually:
Close the valves on the engine to preserve coolant
Drain the long lines into a bucket
Fabricate a U-shaped fitting from elbows- 1" is common heater size, but verify. I like barbs on mine vs smooth.
Post some pictures for better feedback. Also helps if you update your profile w bus info/location.
Get reading !!!
