Old 07-08-2019, 05:59 PM   #1
NomadicBus's Avatar
Chassis: Chevy Express
Engine: 3500
Removing heater from short bus
Hey guys, so this is my first post/encountered problem. This heater under the seat! I have a 99 Bluebird chevy short bus that Iím converting into a food truck and I need it gone. Besides that, I live in Florida, def no need for that extra heater.
Previous owner says it never worked but I want to know what to do to take it out safely and how! Lol
If anyone can please help and point me in the right direction it would be highly appreciated. Thanks. I provided a few pics below of the hoses and wiring that Iíve followed to the back of the driver seat. I located it through some info Iíve gathered on other threads. Also included a pic of the fuse box just incase.
NomadicBus is offline   Reply With Quote
Old 07-08-2019, 06:08 PM   #2
Trace the fluid lines back to the motor. Find where the coolant comes out and where it goes back in . Remove one line, cut the other short and route it into the opening left where you removed the other line. There's a lot of coolant in the lines, so be ready for that mess. You want to keep the front heater as it is the defroster and drivers heat.
Old 07-08-2019, 09:24 PM   #3
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Mine was a pain... I had a few lines and "Y's" to deal with. It wasn't a cut two and loop one back like I thought it was. I had to look up Duramax engine cooling lines routing and figure out where to make the loop...
Just getting started on short bus build...
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel 4L85E Transmission
Frochevy is offline   Reply With Quote
Old 07-11-2019, 10:53 PM   #4
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
Mind sharing how you did it? I'm gonna need to dig into mine sooner or later also
dazdconfsd is offline   Reply With Quote
Old 07-13-2019, 09:33 PM   #5
Coachwork: Ford
Chassis: E450 Super Duty
Engine: 7.3L Turbo Diesel
Rated Cap: Over 1 million bad ideas
Ditto!
I was thinking that I should be able to pull the lines from the under-seat radiator and just "short" those together under the bus to unblock the floor work I need to do. At some later date, I may want to re-install some kind of heater in the back.
cweiss is offline   Reply With Quote
Old 07-13-2019, 10:02 PM   #6
HazMatt's Avatar
Chassis: IH 3800, 8 window
I have no doubt that I'm the outlier, here. It's a role I to which I'm accustomed...
I left the dual-fan terminus intact, along with the sideboard vents in mine.
Being how I've the especially gutless 175 HP variant of the T444E, I want to be able to shed excess heat, muy rapido.
Easily built around, and besides- I live in Texas. What's a little extra 210į inside..?
