Old 06-13-2018, 03:17 PM   #1271
Chassis: International 1753
Engine: 6.9 International
if you are working on Navistar they give away the diagnostic software that will work on everything up through the VT-365 which is up through 07 I think?
for cummins and Cat im not sure if the software for the older engines is cheap or not..
once you get into that 08+ stuff then things get really hairy as far as repairs.. special tools and much more secure computers (so people dont defeat power-sucking emissions stuff)..
Cummins still charges for their diagnostic software, as does Cat. Both diagnostic suites can be found pirated online for free, or a minimal charge. Use at your own risk because they've been known to carry viruses. Also, those programs are usually a year or two out of date, but are still somewhat functional diagnostically.
As a side note, the pirated stuff is usually what's found on the "all in one diagnostic lap top" that you can buy on ebay, and craigslist.
As far as the reprogramming goes, both manufacturer's require a subscription and internet access to work. That kind of stuff is purchased directly from the distributor and is only available to dealerships and certain school districts.
There are tuners that use back door methods to create and load custom programming onto an ecm. Use those guys at your own risk. I know of a guy in Canada that's pretty good at it. Sadly, there are more out there that aren't any good. I've seen examples of new engines ruined by some hack tuner working out of the trunk of their car.
Old 06-13-2018, 03:21 PM   #1272
Originally Posted by Whatthefak View Post
I was just wondering how long it would take him to show us all he unlocked a mt3060
If I had figured that one out I wouldn't trumpet it around. You'd have lawyers on your a$$ faster than ants at a picnic.
I've been wondering if this could be challenged, or if it has already been litigated. Anybody know how the John Deere reverse engineering case came out? There must be other applicable case law on this. For instance, the general aviation industry got a pretty much blanket exemption from product liability on anything older than 15 years.
I would think that the 15-year rule, combined with the obvious fact that our use is obviously outside the original design wheelhouse, coupled with "I own it, it has that capability, you have no right to protect me from myself, and I'm not a signatory to any agreement you may have had with the original manufacturer" should be enough to make it happen. OTOH, they may be in a legally tenuous position and relying on the fact that ain't no skoolie with the bucks to litigate this.
Sorry for the threadjacking.
Old 06-13-2018, 07:09 PM   #1273
If I had ANY of this stuff figured out I'd be distributing the info all over the web. For free.
Roll Your Own Build Thread
Old 06-16-2018, 08:25 AM   #1274
You can always buy one of the rust buckets up here, even with fuel home you'd still be 3k or so
So after sitting on it and thinking a lot THIS^ is the route we're taking.
We're just gonna buy another bus for parts.
Engine swap party anyone?
Old 06-16-2018, 12:01 PM   #1275
the parts bus is the way to go if it is a good runner.. rusty northern bus with a good drivetrain...
Old 06-16-2018, 01:32 PM   #1276
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
I can get you the number for a bus seller here it's a contractor that does all the school routes around me mostly Fe or conventional. Rusty but 2-3k some lower
Whatthefak is offline   Reply With Quote
Old 06-20-2018, 04:48 PM   #1277
466 on CL
https://limaohio.craigslist.org/hvo/...617439370.html
Old 06-20-2018, 07:21 PM   #1278
Originally Posted by dan-fox View Post
Good price!
I'll look for something like that if my summer plan doesn't pan out. I'll PM you...
Old 07-02-2018, 09:07 AM   #1279
Had a good swing and a miss on an OH bus that went a little too high for a parts bus for me.
Got a couple of buses I'm scoping out now, hopefully something will happen and we'll have our bus up and running 100% this year.
I just want a solid, good running engine and newer tires than my bald recaps.
Old 01-11-2019, 09:39 AM   #1280
Bus may have found a new owner. Shaun offered me cash for it.
It would be tough to let go, but having another bus we like even more sure helps. Gona think on it for a day or so.
He's not had a bus of his own and I think he's really enjoy it. He's even talked to a mechanic he went to HS with and can get it fixed.
Too many projects, too little time.
