12-17-2017, 05:39 AM
#401
Originally Posted by syntaxterror
Eccb
Hope you get it softed out atleast yor are home and not on the road. Does your bus have a split radiator/inter cooler?
Thanks Joe
Nope- full rad , full intercooler.
On another note- I'm getting no smoke from the exhaust. None at all.
12-17-2017, 06:15 AM
#402
Rated Cap: 65 pax
Your luck is still holding out, because this coolant problem didn't occur on the trip from TX.
Perspective [emoji4]
Sent from my iPad using Tapatalk
12-17-2017, 06:30 AM
#403
Exactly.
I'm not all butt-hurt about this. Has it ruined my weekend? maybe.... But at least its in a place I can work on it.
If all else fails there's a semi-reputable diesel repair shop two miles up the road from the bus.
12-17-2017, 07:04 AM
#404
Just rolled another one, and are heading over to meet up with Josh and Hillary at the local Starbucks.
12-17-2017, 04:13 PM
#405
Originally Posted by jordan76
An 8.3 in a bus that short would be wild.. and unlikely. Can you get the VIN #?
Sent from my SM-G920T using Tapatalk
I will try to get vin
Sent from my SM-N950U using Tapatalk
12-17-2017, 04:14 PM
#406
Make SURE its an 8.3. Never seen one in a bus that size. That would be AWESOME!
I got some bad news today. Fired up the bus, and ten minutes into running I saw coolant pooling under the passenger side front of the engine. Above the waterpump. Behind the alternator, under the thermostat housing. I'm 99.9% sure that the culprit is the front engine cover aka timing cover. The spot where the leak is coming from would be right where the coolani inlet and outlet to the block are.
Anyone replaced this before? Looks do-able but like a huge job.
Oh no. What do you do?
12-17-2017, 04:15 PM
#407
That would not be a slow bus. If that bus is in good shape you won't likely be disappointed.
Robin, I haven't seen another one with that size. It would be a good thing you're saying?
12-17-2017, 05:02 PM
#408
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
12-17-2017, 06:14 PM
#409
If that's a shorty in reasonable condition with an 8.3, I'd consider buying it myself.
Is that an auction vehicle?
That's an unheard of setup in a bus. It's a unicorn, even if someone had to make it happen by swapping in the 8.3.
That's a lot like CB finding a shorty with the 466. It's worth fixing up if it needs it. I've got to be curious about how much it would take to buy that shorty.
Robin
Nobody's Business
12-17-2017, 06:50 PM
#410
Thanks to Josh, the electrics are working. It was that solenoid that wasn't showing any power. He fixed it right up.
The only thing that doesn't work now is the noise kill button, that I can live without!
There must have been some kind of short in the buzzers for the doors, as soon as the electrics went to working the buzzers wouldn't stop. Disconnected them, no harm to the interlock! No buzzers, bus starts and runs great, and almost everything is now working.
The front cover is the next order of business for sure.
That will be a big job.
12-17-2017, 06:54 PM
#411
Originally Posted by debbiejay4444
ECCB, I have the option to purchase this bus. Does anyone know anything about it? Thomas Bus with Cummins 8.3 motor. Looks similar to yours.
Find out soon, someone will scoop that kind of bus right out from under you!
If that happens, don't post about a prospective bus publicly in the future.
Lurkers are digging for the info as we speak, I can almost assure you.
Even if its a 5.9, with the right transmission that would still be a killer setup for a short bus.
12-17-2017, 06:58 PM
#412
yes!!! score!! and kudos to Josh to getting your electrics back up and running!! what was it? the small feed wire not getting powered?
12-17-2017, 07:02 PM
#413
The two big solenoids- one was corroded badly down in the bottom where the contacts are. He took it out, cleaned it up inside, and its working again. But since the MAIN solenoid was the one with the corrosion, he swapped them for the hell of it.
remember when you told me to check those solenoids- well you were right, and that one that I couldn't get any voltage at was bad. Thanks man!
And a BIG thanks to Josh! He's a hell of a nice guy, that Josh!!
12-17-2017, 07:09 PM
#414
And don't forget handsome!
12-17-2017, 07:13 PM
#415
I must say, you're quite the looker!
No one ever made a HF mulimeter look so sexy!
12-17-2017, 07:35 PM
#416
Even got the WC lift working.
12-17-2017, 08:34 PM
#417
My apologies for the video quality. Making vids is not my forte.
But here's as good a view as I could get of the leak on camera-
12-17-2017, 08:35 PM
#418
but the REAL question is does the Air-conditioning work
12-17-2017, 08:39 PM
#419
One compressor kicks on and off, the other I don't think is doing anything.
The switches are shagged, but both front and rear blow cool air on all the settings.
12-18-2017, 09:29 AM
#420
I get a manual and look into what's needed to fix it. Probably hand tools and a gasket set. And about 20 hours of work.
