Old 12-17-2017, 06:39 AM   #401
Originally Posted by syntaxterror View Post
Eccb
Hope you get it softed out atleast yor are home and not on the road. Does your bus have a split radiator/inter cooler?
Thanks Joe
Nope- full rad , full intercooler.
On another note- I'm getting no smoke from the exhaust. None at all.
Roll Your Own Build Thread
Old 12-17-2017, 07:15 AM   #402
Rated Cap: 65 pax
Originally Posted by Robin97396 View Post
Your luck is still holding out, because this coolant problem didn't occur on the trip from TX.
Perspective
Sent from my iPad using Tapatalk
WanderWoman is offline   Reply With Quote
Old 12-17-2017, 07:30 AM   #403
Originally Posted by WanderWoman View Post
Perspective
Exactly.
I'm not all butt-hurt about this. Has it ruined my weekend? maybe.... But at least its in a place I can work on it.
If all else fails there's a semi-reputable diesel repair shop two miles up the road from the bus.
Old 12-17-2017, 08:04 AM   #404
Just rolled another one, and are heading over to meet up with Josh and Hillary at the local Starbucks.
Old 12-17-2017, 05:13 PM   #405
debbiejay4444's Avatar
Originally Posted by jordan76 View Post
An 8.3 in a bus that short would be wild.. and unlikely. Can you get the VIN #?
Sent from my SM-G920T using Tapatalk
I will try to get vin
Sent from my SM-N950U using Tapatalk
debbiejay4444 is offline   Reply With Quote
Old 12-17-2017, 05:14 PM   #406
Make SURE its an 8.3. Never seen one in a bus that size. That would be AWESOME!
I got some bad news today. Fired up the bus, and ten minutes into running I saw coolant pooling under the passenger side front of the engine. Above the waterpump. Behind the alternator, under the thermostat housing. I'm 99.9% sure that the culprit is the front engine cover aka timing cover. The spot where the leak is coming from would be right where the coolani inlet and outlet to the block are.
Anyone replaced this before? Looks do-able but like a huge job.
Oh no. What do you do?
Old 12-17-2017, 05:15 PM   #407
That would not be a slow bus. If that bus is in good shape you won't likely be disappointed.
Robin, I haven't seen another one with that size. It would be a good thing you're saying?
Old 12-17-2017, 06:02 PM   #408
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by debbiejay4444 View Post
ECCB, I have the option to purchase this bus. Does anyone know anything about it? Thomas Bus with Cummins 8.3 motor. Looks similar to yours.
Wow, Never saw a ISC in a shor-tay.
Lift up the hood !!!!
Old 12-17-2017, 07:14 PM   #409
Robin97396's Avatar
If that's a shorty in reasonable condition with an 8.3, I'd consider buying it myself.
Is that an auction vehicle?
That's an unheard of setup in a bus. It's a unicorn, even if someone had to make it happen by swapping in the 8.3.
That's a lot like CB finding a shorty with the 466. It's worth fixing up if it needs it. I've got to be curious about how much it would take to buy that shorty.
Robin
Nobody's Business
Old 12-17-2017, 07:50 PM   #410
Thanks to Josh, the electrics are working. It was that solenoid that wasn't showing any power. He fixed it right up.
The only thing that doesn't work now is the noise kill button, that I can live without!
There must have been some kind of short in the buzzers for the doors, as soon as the electrics went to working the buzzers wouldn't stop. Disconnected them, no harm to the interlock! No buzzers, bus starts and runs great, and almost everything is now working.
The front cover is the next order of business for sure.
That will be a big job.
