12-26-2017, 07:15 AM
#601
You too, Sandi!
I won't be my usual TALKATIVE self, I've suddenly got acute laryngitis. Got to family xmas dinner and suddenly my voice was all but gone.
yowsers hope you could at least smoke!
12-26-2017, 07:29 AM
#602
Its the weirdest thing.. All of a sudden my voice just went out.
Kinda like my front timing cover lol.
Tis the season of FAIL here
12-26-2017, 02:52 PM
#603
I measured my bus and Sandi's next to each other. Her is 2003, mine 2004.
her bus sits one inch +/- higher than mine. From center of hub to edge of wheel arch trim.
Gonna do some more lookin n measurig, but I'm now convinced that 10R's will fit with no trouble! My body to chassis mounts are different than my previous buses. I'll snap a pic, but they're spring loaded. I guess so as the rubber slowly degrades they stay tight. Nice.
Gotta get pics of my bus and Sandi's next to each other.
12-26-2017, 08:55 PM
#604
I'm going to talk to the diesel shop again tomorrow. See if I can get it in for some diagnostic work and find out about the general health of the engine. I want to really make sure everything's in order before we proceed with fixing anything.
12-27-2017, 07:27 AM
#605
I've got a question-
Is it even worth sampling my oil if I just changed it? Its only got about 10-20 miles on this oil since the change. The leak sprung up just after changing it.
12-27-2017, 09:05 AM
#606
Yes, we want to see pics! -Hillary
12-27-2017, 09:20 AM
#607
Got some GREAT news after talking to the IC dealer here. They only have one part number for the front cover for my year. Fingers crossed but I think I'm in the clear as far as having to remove the rear timing cover.
A new outer cover is $950. They have one in stock, otherwise the part is on national backorder. I think I'll go ahead and get it. They put it on a ticket for me.
12-27-2017, 09:26 AM
#608
Do you still have the old oil that came out of that engine? Test it.
I would also test the new oil because if it has coolant in it, you will be loosing your rad hoses, heater hoses etc. It won't happen immedietly but overtime they will rot away insideand get a major overheat.
12-27-2017, 09:33 AM
#609
Naw, we got rid of the old oil, but I didn't see any signs of coolant in it.
Will definitely check the oil, but with only maybe 20 miles of operation I doubt it would be too helpful. I've only ran the engine maybe 20 minutes and 1/2 mile since the front cover coolant leak started.
I'll start with replacing the front cover and gaskets. Then get everything tested thoroughly. Runs great, other than the leak. Hopefully it stays that way.
12-27-2017, 09:40 AM
#610
You should be good but I am just passing along what I know from past experience. i had an Audi and got a new head gasket installed. I was supposed to get it retorqued after say 2000kms. Well, dumb me, let it pass and got a nice mix of oil and coolant in the block. Not good so beware.
PS: As a sidenote, it's -28C with -35 windchill, enjoy your Sunshine State CB! Alos, 3 feet oF snow in the driveway to blast out.
12-27-2017, 09:41 AM
#611
Chassis: Saf-T-Liner MVP ER
Without at least 1000 miles on it there is a limit to what the lab can tell you.
12-27-2017, 09:43 AM
#612
BlackJohn- OUCH that sounds like no fun at all! I can't deal well with cold temps at all!
12-27-2017, 09:45 AM
#613
May be more beneficial to test it after the repair and some road time then.
12-27-2017, 09:50 AM
#614
I have to second the re-torquing procedure. Really important step anytime the head is off and on. Also an easy one to forget. Put a Post-It note on the dash!
12-27-2017, 09:53 AM
#615
You get used to it CB. Most commercial diesel vehicles are never shut off,snowplows, ambulances etc. Depends on how you dress and what your wear, wool is good. Still, it is killer cold so not really enjoyable unless I keep rollinn.
Strange thing, I can't stand your heat, don't know how you do it even with unlimited beer....
#616
fantastic news that there is only one part number on the cover.. id do a teardown and see what yours looks like.. maybe you get lucky and just that crappy O-ring rubber gasket is bad.. not sure why navistar chose to use that style gasket on lots of their stuff but they do.. and they seem to leak.. the 444E's were notorious for thermostat leaks.. that gasket material is the same as your timing cover..
usually as noted, water in the oil is pretty easy to spot. oil in the water as well.. I can atest to Blackjohn;s retorquing of bolts.. which shouldnt affect you arent pulling the head gaskets.. but I would pay attention to bolt torques and torque order when putting that cover back on.. anything that is large and has a gasket is real important not to warp due to incorrect torques or "pinch-warping" associated with tightening the bolts out of order..
I need to be in florida big time.. just havent been able to get away! gonna be near 0f each nioght for the next 6 nights.. on a good note my DT-360 kicked right over this AM after sitting since TG weekend not being plugged in.
12-27-2017, 03:28 PM
#617
The local truck shop said it would be a month before they could look at it.
Tempted to tow it on over to the navistar dealer and have it done. Would be a $350 tow. But I'd rather take someone the bus whole and running than get into some situation in Shaun's driveway and have to haul it off in pieces.
I really hate to spend the money, but I'm not confident in doing this alone with limited tools and resources. If the tab isn't too bad from the front cover replacement I could have a coolant pressure test and maybe compression test done while its in. I definitely don't have the tools for either of those.
12-27-2017, 03:38 PM
#618
If I could, I'd live even closer to the equator. But the further south in Fl you go the dodgier it gets.
12-27-2017, 03:47 PM
#619
Speaking of the equator, I hear most politicians and other government heads are moving their families to the other side of the equator. Argentina sounds nice, and diesel is cheap.
Robin
Nobody's Business
12-27-2017, 04:15 PM
#620
Well CB, there is one I have never heard before...can you splain : "dodgier" please?
Just thinking here, your bus walked home from Texas like a champ. No need for compression test there I don't think. You must have felt how it holds the revs up accelerating thru the gears too since getting it.
Auto parts places will loan you test, ..easy peasy to do for coolant pressure test.
I suggest getting towing coverage for all your vehicles in one package like we have up here. Annual cost pays for itself if towed once. Here a big wrecker costs $185/hr, mileage included, so yours seems way high for the distance.
I understand how Shaun might freak about doing this at his place but you can do this repair. Won't happen overnight but very doable to change the front cover. I don't get why you can't do this at home really. All the support you need in in this place and you are having a get together so get some help with this.
Over and out,
