05-24-2019, 03:52 PM
#21
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Bluesky
It's been awhile, so here is an update.
I did get a new controller and installed it. The replacement was slightly different and the gas line is a different angle. I got new copper tubing, comes in a 5 foot roll. The gas line connects at a T behind the fridge(accessed outside), and snakes under the back of the hot water tank, there it makes a u-turn out the back of the water heater housing at the precice angle to mate up with the brass fitting to the controller. This angle had to be right on to get the threads started, but it’s too tight under the cabinet to do any bending. I put it in place, looked, measured, pulled it out made a bend, put it back in and figure out how to adjust it again. This new copper tubing seems softer than the vintage tubing that came out of the bus. I’m o.k. with bending it, the cutting was a problem. My pipe cutter would put a groove near the end that prevented the compression fitting from sealing. I finally got it in and pressurized the gas line. I had read about testing for leaks with soapy water. I put some dish soap and water in a squirt bottle and the test works! There’s a bubble. I pulled the line out again and redid the bends and recut the end. It had a loop to get out, I had to change that and have a more precice bend, but I made it work. I needed about 5 feet of tubing, so nothing to spare, and nothing flexible in this line. I put it together, and didn’t get back at it for about a week. I found that I had left the gas on for the week. The tank wasn’t empty, so I was happy the system was solid. I still have to reinstall the thermo-couples, the two tiny aluminum tubes that tell me they want to snap if I look at them. I didn’t want to fill the water tank since it was last fall and freezing temps were on the way. I better get it together while it’s still warm!
The generator: I drained the old gas, took apart the carb and saw it was clean, oil was full. I found a gas station that sells 100 octane gas. I put some in and it fired right up. I’m not sure if I’ll use this generator on the bus, as it is, it’s too tall to fit under without hanging below the body. I might be able to offset the gas tank to mount it higher.
you have more patience than I do - I'm 80 years old, and with that bus it would still be sitting in my driveway as they hauled me off to my funeral - lol
