Old 02-26-2009, 09:58 AM   #21
Hearse Driver's Avatar
Chassis: Ford B700
Engine: 5.9L Cummins
Re: short-bus advice on engine, tranny etc
Originally Posted by the_experience03
...The TH475 is another beef part because it uses straight cut gears on the planetaries making it stronger. It is usually identified by a large parking brake drum on the output though the TH400 could be found this way as well. As for 4 speeds...I've never seen a 700R4 in one, but that doesn't mean they didn't find their way into those trucks. I think you're probably more likely to find a 4L80E or an Allison.
I haven't actually gotten under there and looked at mine that closely, so I was wondering about this myself. Mine is a 4 speed. After Googling pictures of a 4L80E, I think that's what mine might be, but I've only looked at it once so far so I can't be positive about that. It does have a parking brake drum on the output though. I'm really not a big GM fan so I can't tell any of their trannies apart after the TH400s. I would much rather have a fuel injected Ford big block in there with an Allison tranny!
At a job I used to have several years ago, I worked on our company's F700 now and then and it had a carbureted 429 with an Allison behind it. Unreal torque with that setup! It was because of that truck that I ended up putting a 429 into my 2 1/2 ton military truck. I didn't have an Allison laying around so I had to settle for a 5-ton Spicer 5 speed.
Originally Posted by Ray_WA
Yup. Yours is a bit longer than mine by about a foot and a half I'd say. I'm very jealous!!!
I'm not so sure that's a bad thing. Sounds like your P30 is almost exactly the same size as my 51 Chevy. I had a floorplan drawn up for it that would have worked very nicely. Only thing that was holding me back was the ceiling height.
What doesn't kill you only makes you... stranger.
https://i746.photobucket.com/albums/x...G_0164link.jpg
Hearse Driver is offline   Reply With Quote
Old 02-26-2009, 11:56 AM   #22
Ray_WA's Avatar
Engine: 6.2 liter diesel
Rated Cap: 24
[quote=Hearse Driver]
I'm not so sure that's a bad thing. Sounds like your P30 is almost exactly the same size as my 51 Chevy. I had a floorplan drawn up for it that would have worked very nicely. Only thing that was holding me back was the ceiling height.[/quote:23c77bs5]
I love the ceiling height of mine!! I am actually thinking of raising the floor 3 inches... both for insulation value and to provide discreet storage space.
-Ray
Pack up your bus and bug out to the hills!
Ray_WA is offline   Reply With Quote
Old 02-27-2009, 07:34 AM   #23
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
P30's tend to have some cool stuff going on transmission-wise. The 4 speeds are typically SM465's, the same granny geared dumptruck transmission that GM used 40 years ago and are tough as nails. Anything newer than about 1986 should have a beef 32 spline output and a hydraulic clutch. 5 speeds tended to be either an NV4500 or a big Clark 5 speed. The Clarks are worth something because it is a heavy, medium duty transmission that comes with the appropriate adapters to go to a Chevy block making them popular with the offroading crowd. Automatic transmissions in the 3 speed variety will be either a Turbohydramic 400 or a TH475. The TH475 is another beef part because it uses straight cut gears on the planetaries making it stronger. It is usually identified by a large parking brake drum on the output though the TH400 could be found this way as well. As for 4 speeds...I've never seen a 700R4 in one, but that doesn't mean they didn't find their way into those trucks. I think you're probably more likely to find a 4L80E or an Allison.
I just read this and I have two trucks and the CAMO-MONSTER with that same trans the sm465 a 1970 c10 a 1971 k10 and the CAMO-MONSTER 1974 GMC 6000. the 70 Ihave had up to 130mph it is stock and has 3.08s. the 71 k10 has 4.56s and will only do about 75 if I realy push it. And the CAMO-MONSTER is a ( ? ) it has gm t170 two speed rearend and has 9.00"/20" and the damn speedo dose not work right now. Andfor the 4l80e it is the reaplasment for the th400 with overdrive and the tail shaft is simuler to the th400 with 6 bolt tail shaft cone. If I had to have a GM 4 speed auto the 4l80e and NOT THAT CRAP THEY CALL THE 700r4 !!!
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 02-27-2009, 08:53 PM   #24
Coachwork: Ward Genesis
Engine: DT466/MT643
Any automatic in a GM/Workhorse chassis Stepvan or minibus after about 1991 will be the 4L80E. Prior to that it will have a TH-40 or TH-475. Nothing this big got the TH-700 (though there ARE people using them now).
The 700 is a great transmission. They work in everything from trucks, to Corvettes, to street rods, to 2-ton Chevelles with 502 big-blocks, to a Super Bee with a crossrammed EFI 426 Hemi. Yes, I absolutely did just say it has a crossrammed EFI 426 Hemi. The guy with the Bee also has a 20,000lb tag-axle Pace Arrow motorhome...and he runs a TH-700 behind a 454 in it. (He owns a trannsmission shop that specializes in 700's.)
Jarlaxle
Any and all advice welcome on my 96 Bluebird short bus MissJaneStrummor Short-Bus Conversion Projects 21 06-03-2014 11:07 PM
1992 Bluebird w/ Cummings engine runs on used tranny oil??? sdwarf36 Alternative Fuels | Electric, Propane, Wood & Biofuels 7 11-18-2012 04:04 PM
Cost of engine rebuild and tranny rebuild? dgorila1 Mechanical and Drivetrains 2 08-07-2011 11:45 PM
Short bus AC install(need advice) Stopbit Conversion General Discussions 4 07-16-2010 03:50 PM
1986 IHC 6.9L v8 non turbo Diesel engine tranny combo 4sale andybus9 Classifieds | Buy, Sell, Swap 0 05-14-2006 11:10 AM
