Old 06-18-2018, 03:09 PM   #1
Shuttle bus roof (sealing emergency hatch?)
Hey! First post, but I have been reading and lurking for quite sometime. We recently picked up 2008 Chevy C4500 Goshen shuttle bus and are in the midst of the demo and was hoping for some guidance as I am planning some pieces...
Anybody have any recommendations for the best course of action to seal the hole of an emergency exit hatch? The existing emergency exit is leaking significantly (between the bus/hatch join, not the mechanicals of the hatch itself) and so I am thinking the best course is just going to be to remove the hatch and close the hole.
I am fast approaching the ceiling demo (walls and floor nearly done) and have been leaving this one as I need a strategy to deal with the giant hole/not entirely certain what my best materials choice will be. I would just replace the hatch but don`t really care to spend the couple hundred bucks for a new one and all of the anecdotal info I have suggests they all leak anyways. I am open to any other thoughts or options!
gybe! is offline   Reply With Quote
Old 06-18-2018, 03:30 PM   #2
Coachwork: None yet
Piece of sheet metal cut about 1.5" oversize.
Drill for rivets, butyl tape, rivet it down and seal the seams.
cycle61 is offline   Reply With Quote
Old 02-07-2019, 02:18 AM   #3
26 inch semi-domed skylights (clear, smoke or white/opaque) on amazon (brand: ICON) are looking appealing to me if I don’t make the hole smaller to mount a maxxair fan. About 100$ for skylight.
Puskara is offline   Reply With Quote
Old 02-09-2019, 09:50 AM   #4
I just retired from doing commercial roofing after 35 years. Go to your local roofing supply company. Ask for a product . Heck here is a link
H.E.R. | Hot Roofs. Cool Solutions.
This is the only product I would use on a build. It is great. I have only used the buckets and sausage rolls.
If you get the sausage roll. Just cut a hole in the end and squeeze. FYI rubbing alcohol for clean up.
And use frog tape to outline your work
Wear gloves and use a brush.
Dr mac is offline   Reply With Quote
Old 02-11-2019, 04:46 PM   #5
I went a step further than a sheet of metal. I figured why not utilize this space to bring light into the bus. On the rear hatch I secure with butyl tape and screws a 26" piece of tinted Lexan. I then mounted the 14" vent fan in the center of it. I then replaced the front hatch with just the 26" tinted Lexan, huge light coming through that one.
Old 02-17-2019, 11:04 AM   #6
Dome
Hereís what I did. Itís a $20 doggy dome off amazon.
File Type: jpg FC1BDA2F-A3C5-4284-AAFC-4535398F2E65.jpg (171.7 KB, 10 views)
File Type: jpg F02354F9-D003-40B0-9D70-B5B00FFC7551.jpg (178.1 KB, 7 views)
Tstege is offline   Reply With Quote
Old 02-17-2019, 12:31 PM   #7
Brilliant, perfect for stargazing too!
Old 02-19-2019, 11:07 AM   #8
Or shooting a fix off the North Star with your sextant, if that's how you're navigating.
Old 02-24-2019, 12:48 PM   #9
graceashlynn.arts's Avatar
Chassis: Blue Bird Micro Bird
Engine: GMC 3500
Interested in this, since I believe I'm having a similar issue. What advice do you guys have to someone who wants to keep the emergency hatch & is on a budget?
graceashlynn.arts is offline   Reply With Quote
Old 02-24-2019, 02:05 PM   #10
Unless it's actually broken, just about any leak can be found and remedied. I would go this route if wanting to save the scape hatch.
