Re: speed
Well, what RPM is the engine turning at 55? The 7.3 tops out around 2500 for sustained running. If it's around there (not at all unusual on a skoolie), 55 is about it unless you change gears.
Check for coolant additive--a test kit is cheap at NAPA or an IH (or Ford) dealer. This engine REQUIRES adding SAC to it or the engine will eat itself! With the additive (about $20, as I recall), it's a 300,000+ mile engine.
Jarlaxle
