Old 05-28-2011, 10:03 AM   #31
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: Splash Party Bus (97 E350)
I think you are the only person ever on this forum to INSTALL seats!
I had this site recommended to me for stickers--www.harrisdecals.com
A buddy did his racecar from them-I plan on doing the same.
Old 05-29-2011, 11:04 AM   #32
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
did you put the vent in or was it there? they are nice to exhaust hot air!!
Old 05-29-2011, 08:36 PM   #33
lapeer20m's Avatar
[quote="Stuff"]did you put the vent in or was it there? they are nice to exhaust
The vent was already there.
Old 05-30-2011, 11:18 AM   #34
lapeer20m's Avatar
Started installing the 3/4 inch hardwood prefinished flooring. Also got my rear a/c fixed! (yah!) The temps went from the 40's a couple of days ago to a high in the 90's today. I hope to get the flooring finished today, and start welding legs onto the new seats. They were meant to attach to the chair rail, so they only have legs on one side.
Old 05-30-2011, 03:25 PM   #35
lapeer20m's Avatar
more progress....I got legs welded onto the seats, and bolted groups of seats to each other. They are not yet bolted to the bus. I have to paint the back wall before i secure the seats.
It's coming together nicely!
Old 05-30-2011, 03:35 PM   #36
Sail Man's Avatar
No surprises here that you would do a bang up job.
Treatment algorithm's rarely survive the first 30 seconds of patient contact.
Sail Man is offline   Reply With Quote
Old 05-31-2011, 08:11 PM   #37
lapeer20m's Avatar
Photos from when i was welding the legs on the seats. I wished i had something a little less heavy duty laying around, but the material i had on hand is 1.5 inch square tubing with 1/4 inch wall. About twice the strength i really needed.
Today i got the remote keyless entry installed. Here is a video:
Installed the inverter....although i seem to have lost that pic..
When connecting the inverter, I like to take the copper ends, smoosh it on the cable, then fire up the torch and fill the empty space inside the copper end with solder.
Old 06-01-2011, 08:47 AM   #38
Diesel Dan's Avatar
Engine: DT466/AT545
So I assume that since you've converted several buses, the Harbor Freight inverters work out well for you? I've had bad experiences with their stuff, including a battery charger and air compressor. So even though I considered the "Chicago Electric" brand, I ultimately went with something else.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-01-2011, 12:14 PM   #39
lapeer20m's Avatar
I have used Chicago electric inverters in most of my buses. One inverter was a Coleman, but it was identical to the chi electric brand, just had a different label on it. This particular one is the new version of the 2kw inverter.
Harbor freight sells a lot of junk. Especially anything that comes with rechargeable batteries.
I have had exceptionally good luck with these cheap inverters. Over the past ten yeArs and hundreds of hours of use, I can recall only two of these inverters I toasted, both as a result of operator error. One was the result of a jello shot that fell directly onto the unit. The second one died while I was spraying the ceiling of the bus wih aluminum based paint. The cooling fan on the inverter sucked in a bunch of alumni paint covering the circuit board with a layer of conductive metal. The only useful thin I ever heard at radio shack invol ing electronics: "once the magic smoke escapes you can never put it back in.
I have destroyed far more alternators than I have inverters. I have plugged in literally hundreds of devices to these modified sin wave inverters and have been very pleased.
Old 06-01-2011, 03:03 PM   #40
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Party bussers here, look at this. wmah School Bus News 9 07-24-2012 05:50 PM
Shopping for a party bus? UniqueGuy Classifieds | Buy, Sell, Swap 0 09-22-2011 03:29 PM
Party Bus v3.0 (TheBusCrew) Bluebus Skoolie Conversion Projects 4 03-15-2011 11:45 AM
Party Bus? spoore Conversion General Discussions 14 03-02-2009 12:55 PM
Disco Party Bus DizzyIzzy Everything Else | General Skoolie Discussions 1 10-08-2007 05:31 PM
