Old 04-14-2017, 01:50 PM   #11
I have a buddy of mine looking for a bus exactly like yours. Do you have any recommendations on where to find one? Thank! NGUYENBUS
NguyenBus is offline   Reply With Quote
Old 04-14-2017, 01:53 PM   #12
brokedown's Avatar
Honestly they are fairly rare... I got mine out of Miami and it was the only one they had. The 3800 series is way more popular. I don't take have anything negative to say about it other than the van style engine setup is a bit less mechanic friendly and it's harder to find info on it due to the being fewer.
Sent from my Nexus 6P using Tapatalk
Follow us on Facebook, Instagram, and Twitter
Old 04-17-2017, 09:09 AM   #13
brokedown's Avatar
My lower AC compressor, the one that cools the front of the bus, has become kaput. Finding a replacement that can ship fast enough to get to me before I have moved along is a challenge! It's a 4663 compressor, which send to be commonly used, but hard to find.
Old 04-17-2017, 10:05 AM   #14
is that the one which wasnt cooling right at ECCB's bus gathering?
a 4663 should be available at many auto parts stores.. its a really common unit...
are you sure the compressor is gone and you didnt just lose the Freon? (loss of freon will shut off the compressor)
one of your units seemed weak when we were running your bus at EC's.. I put my hand on both suction lines and one of them wasnt cold though the unit was running..
Old 04-17-2017, 10:16 AM   #15
brokedown's Avatar
They were both low at the meetup, I filled them back up and they worked great. The lower one, the pulleys had a good amount of movement and was making noise for a while. The clutch finally went out yesterday. It's physically broken. I haven't had any luck on the chain parts store web sites but I will stop in at a Napa or similar when I get to a "real" town.
Old 04-17-2017, 10:48 AM   #16
brokedown's Avatar
I could bring the compressor back to life by replacing the clutch assembly, but with the amount of back-to-front movement the pulleys had its a matter of time before it fails again. I'd rather just swap the compressor out now and be done with it
We're in the middle of Texas at the moment, and we have the read AC operating just fine.
Old 04-17-2017, 10:51 AM   #17
a trick ive used when travelling and needed a part or item , was to ship to a UPS store in a town I was going to be in.. or if an address was required, you can provide about any near you, then get o nthe shipper website, like UPOS or FEDEX and redirect to be held at a store.. ie UOS store, or FEDEX Office location.. or sometimes you can even hold stuff at the depot to get it quicker..
be careful not to over-charge those or get air in the system.. that will wipe out a compressor... sounds like yours just wore out..
Old 04-17-2017, 11:15 AM   #18
brokedown's Avatar
I got the fancy gauge and filler kit, so no worry as far as keeping it at the right levels. Autozone will rent me all the specialty tools I need to do the compressor replacement, even if they can't get the compressor itself.
Old 04-17-2017, 11:19 AM   #19
the big one to have is the Vacuum pump... thats the important one.. I dont know if they rent those or not.. ive never tried.. but thats the impoortant part is getting the air out of the system, moisture and air will cause lack of cooling and ruin a new compressor..
Old 04-17-2017, 11:23 AM   #20
brokedown's Avatar
Yep they rent the vacuum pump. The nice thing about autozone is their tool rentals are free, they have a deposit you get back when you bring the tool back.
