03-27-2018, 02:39 PM
#41
Engine: GMC
Rated Cap: 42
Great job on this build! I do have a question for you. When you were talking about your homemade gray tank you said
"Used a end cap then drilled in a 3" male adapter to run the drain."
Did you spin weld an adapter to the PVC end cap or did you drill a hole in the PVC end cap and put in an adapter?
03-27-2018, 04:08 PM
#42
I really wish I had takes pictures but I welded a female adapter to the in side of the cap then I spun in the male after the female dried for about 48 hours
Sent from my SM-G920V using Tapatalk
03-28-2018, 01:55 PM
#43
Engine: GMC
Rated Cap: 42
Thanks for the information. I have a piece of 10" pvc irrigation pipe that I was thinking about using for a tank but I have not seen it done before and I could not figure out how to attach the fittings so I put that idea on hold. Now you have got me inspired to give it another try.
03-28-2018, 01:57 PM
#44
Yeah there you go think outside of the box. When I get home from work I'll try and remember to post a better detailed picture
03-28-2018, 03:06 PM
#45
Without any baffling, there is going to be one heck of a lot of force in the water moving back & forth or side to side. Think great big hydraulic hammer.
03-28-2018, 03:11 PM
#46
Hey Tango you are totally right. I honestly really only plan on taking the bus to real camp grounds for now. So I plan on having my tanks empty for traveling for now anyway. But thank you for your comments. And I have to tell you I am a big fan of your build. I can't wait to see the finished product. With the level of detail you have been doing it's going to be one for the books.
03-28-2018, 03:29 PM
#47
Thanks for the kind words Josh. One solution would be to cut and cap the 10" pipe into short (2"?) lengths but cross connect several to form a self baffled unit. Near as I can tell, a 2' length of 10" pipe would hold about 8 gallons of water. A "row" of 5 would give you around forty gallons.
Just a thought. There would still be sloshing, but it comes back to the old E=MC2 thing. Limit the mass & velocity and the energy becomes manageable.
03-28-2018, 03:49 PM
#48
That is a good point the more baffling the better for sure.
03-28-2018, 04:46 PM
#49
Year: 98
definitely wild **** is going to happen at light speed
later j
05-10-2018, 07:37 PM
#50
Rated Cap: 19
I don't know how I missed your build but well done! I wish I'd done my counter top like you did.
05-21-2018, 07:29 PM
#51
05-22-2018, 09:10 AM
#52
Engine: Ford 7.3
I like what you have done.
I really like the skylight idea.
I will be stealing that one.
05-24-2018, 07:48 AM
#53
I really like the platform on the back---Great to mount Bicycle Racks on. Your project looks great.
