Old 06-09-2018, 10:31 PM   #101
plfking's Avatar
Rated Cap: 34
Mounted my sample awning yesterday.....had a 1 1/2 hour downpour this pm, and it worked great......rain was blowing sideways and it still didn't make it inside the bus. Ordered 5 more this morning, which will reach the length of the bus on both sides.
Two of my paddle latches didn't work, nor did the fuel door lock.....so I ordered some t-handle cam locks from Ebay. They have a nice finish and work very smoothly. Made my generator and battery doors out of metal plate, but didn't like the look of them, so I'll re-do them in wood tomorrow, which I should have done to start with, but never thought of it.
Don
The Busted Flush
Old 06-10-2018, 09:22 PM   #102
plfking's Avatar
Rated Cap: 34
Got my wooden doors made and mounted. They'll go well with the accent pieces I have planned. Threw some red and black paint on just to see the contrast.
Moved the ribs from the new door area to the other side of the bus......really like the way they look. Still need to grind on them a little, but I'll do that when I do my final prep for paint.....leaning towards the burgundy color closest to the rear wheel.
Don
The Busted Flush
Old 06-11-2018, 10:24 AM   #103
desertfather's Avatar
Coachwork: Wayne Lifeguard
Nice job with the doors. Are you planning to add other accents to make it look like an old-school "woody"?
desertfather is offline   Reply With Quote
Old 06-11-2018, 10:42 AM   #104
I like that idea!
Roll Your Own Build Thread
Old 06-11-2018, 08:16 PM   #105
plfking's Avatar
Rated Cap: 34
Yes......will be adding a 4" wide wood strip just under the windows which will run all the way around the bus body, and a 2" wood strip about 2 ft below that that will just run the length of the sides.
Also in the process of making/designing a wood hood scoop....got about halfway done with the first one, then set it on the bus and realized that its' curves (think late 60s Firebird grill) didn't look good at all with the blockiness of the hood, so I'm starting over. It's going to be functional as well.....Hybuzz put one on his bus and says it really moves the hot air out from under the hood and away from the firewall....I'm all for that.
I like wood on vehicles....here's a 75 Blazer I did years ago because I didn't want to spend the $$$ to replace rusted quarterpanels.....it quickly got out of hand, but I had a ton of fun with that truck. I'll curb my enthusiasm with this bus build.
Don
The Busted Flush
Old 06-11-2018, 10:49 PM   #106
joeblack5's Avatar
Year: 98
Wow, that looks cool, I wish I had that king of patience with wood, sure looks nice.
Later J
Old 06-12-2018, 10:26 AM   #107
That truck is an incredible piece of work! Can't wait to see what you do with the accents you're describing on the bus.
Old 06-12-2018, 08:11 PM   #108
plfking's Avatar
Rated Cap: 34
Thank you gentlemen.
Don
The Busted Flush
Old 06-15-2018, 09:24 PM   #109
plfking's Avatar
Rated Cap: 34
Embarrassed to say that yesterday was the first time I washed my bus...it is now Kentucky dirt-free. I empathize with y'all that own the long buses....took my almost 3 hours to do mine, and didn't even touch the roof or wheels. I then attacked it with every color-combo I thought I'd like....will go with burgundy with silver and black ribs....haven't finalized which ribs will be which color.
Got my awnings painted...will paint above my windows tomorrow morning, then bolt and seal these bad boys in place tomorrow pm.....then start sanding and prepping the rest of the bus.
Since day one I've been trying to figure a way to use my flashing lights fore-and-aft as openings to let fresh air through the interior while driving.....haven't figured it out, so will cut 6" x 36" openings in the front and rear caps, frame the opening, then build two tempered- and tinted- windows to fit. The windows will fold up and back inside the bus while traveling....should keep the interior a lot cooler while rolling.....will have to make sure the paper towels and toilet paper are securely locked away.
Don
The Busted Flush
Old 06-17-2018, 05:02 PM   #110
plfking's Avatar
Rated Cap: 34
Got the awnings mounted and top side painted. I used 3/8" rubber weatherstripping all along the top edges and sides, and compressed it down to about 1/8" by using about 12 tek screws on each panel. The awnings really aren't as noticeable as I thought they might be.....I like the way they turned out. I already know they'll keep sideways rain out, and with the approx. 6 1/2" overhang they'll keep at least a couple more hours of midday sun from directly shining inside.
To be on the safe side, I bolted the 3 awnings on each side together, so if the screws fail, they're gonna have to ALL fail for this thing to become a guided missile into someone's windshield.
Went for a ride to check everything out.....no noticeable vibrations or movements at 55 mph. MPGs actually increased about 20%.....I must be getting some lift from them, which will also mean less wear on my tires.
Don
The Busted Flush
