01-01-2020, 06:13 AM
#361
I'd just like to paint one I own eventually.
01-01-2020, 11:15 AM
#362
Rated Cap: 34
Just find a local tag artist......he'd probably do it for free if you gave him an extra case of paint.
I knew painting mine early in the process would motivate me to keep making steady progress......the quicker it started looking like a camper, the better.
01-01-2020, 01:25 PM
#363
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
How many do you own?
01-01-2020, 04:46 PM
#364
Finally down to one. Ive had several.
01-01-2020, 06:50 PM
#365
Rated Cap: me + 1
You have been watching the results of people paint their bus with all kinds of paint longer than I have. To what paint/method are you leaning?
01-02-2020, 06:18 PM
#366
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
That's a great idea! Our collective tastes are a bit more conservative, but if we had bus #2, I'd be very tempted to pursue something along those lines.
You bus continues to rock & inspire. With the exception of the initial gutting and sealing the floor, we're taking an 'outside-in' approach too. Hope to have the painting done by March. Then the fun begins!
Go away. 'Baitin.
Our Build: Mr. Beefy
01-02-2020, 09:56 PM
#367
Part of me is hoping to go this route -- I have a certain artist is mind...
Enjoyed going through your build thread. Really like the wood work and how you did the roof deck...
I'm curious how you find the transom windows working out now that the interior is built?
And after removing the oem doorstep you then added a door step in front of the rear wheel -- it seems like it hangs down as far as the one you removed. Have you driven on any rough roads yet to see if it's a clearance problem?
01-02-2020, 10:40 PM
#368
Rated Cap: 34
Mine too......but the guy who did my tats has done some pretty nice and tasteful murals also. I was thinking CB could get a nice Celtic flag on his for pretty cheap, then keep it or change it later.
What's your color scheme going to look like?
01-02-2020, 11:07 PM
#369
Rated Cap: 34
Thanks for the props!
I just finished framing those windows in the last 6 weeks or so, and haven't driven it since then. The wind flow was nice before framing (after most of the cabinets and all the countertops were in), so I don't think it will be any different now.
My original step had about 8" clearance.....the one I built is between 13-14". I've got a 'circuit' I drive after installations to make sure nothing falls on my head....about 10 miles of pot-holed paved road, 2-3 miles of dirt road, plus a couple of rutted, high-crowned 'woods roads' out to some tobacco barns my grandfather used to own. I haven't seen any high-centered issues with the step, although it does do a good job of pulling up weeds. I did design it so I can cut the 'legs' and raise the clearance another 4-5", but I don't think I'll need to. If I do, I'll have to carry a little stepstool around with me, as my knees aren't what they used to be.
01-03-2020, 12:14 AM
#370
Rated Cap: me + 1
I spent about 30 minutes staring (spacing out) at the last pic on page 16. Trying to figure out ways to make that side door treatment work for my bus (I have a Thomas flat nose (I didn't really come up with anything that would work into my current plans except turning my front door stairwell into an indoor/outdoor shower).
I did however keep seeing a vision of a shower with a shallow stainless tub right where your stair landing is (the bottom of the tub was set so that there was enough standing headroom at the side of the bus to be comfortable). There was a short 1 or 2 step metal stair that hinged so that it stowed in the landing for travel and could be flipped down when parked. The door was sealed so that the inside was waterproof. The 2 sidewalls were also waterproof and there was a curtain facing the hall. With this setup you were able to shut the door and take a shower or take a shower before coming inside - good for working, cooling off, or swimming. My imagination gets carried away sometimes ... I must of seen a dozen versions of this concept.
01-03-2020, 09:34 AM
#371
Chassis: CE300
Rated Cap: 23
Surprised you haven't done that already, ECCB, based on your obvious passion
Has anyone considered vinyl wraps?
Our paint plan isn't exactly earth shattering. Just replacing factory colors with others. Pretty boring now that I think about it, lol. But considering the cost of paint, I think we're OK with boring at the moment The brown will be wood, not paint:
http://www.skoolie.net/forums/f13/pa...tml#post363344
Go away. 'Baitin.
01-03-2020, 10:31 AM
#372
Chassis: Collins
Engine: 6.6L LMM Duramax
I tailgate in the same lot with a State Farm Insurance rep. He has an older Ford short bus that has a vinyl wrap on it. He said it makes it look good and hides a lot of bad rust underneath in the body.
I also wonder if this makes a rust issue even worse trapping condensation?? I also don't think wraps are on the cheap side... Never priced one tho?
01-03-2020, 03:27 PM
#373
Rated Cap: 34
Nothing wrong with that idea......I've read of a few folks who did that, and there is plenty of headroom while standing in my stepwell. The only drawback would be wet steps leading into the bus, but nothing a towel or bathmat wouldn't fix......would be worth it for a roomy shower stall.
01-03-2020, 03:34 PM
#374
I'm building in a tub that will project only 6" below the level of the factory floor, and that's about as far down as I can go and still get the natural drain over to the top of a 9" high grey water tank that will be flush with the bottom of my side skirt. You could have a shower stall lower than that in the stepwell but you'd have to have a pump for the drain.
01-03-2020, 04:55 PM
#375
Next door neighbor that I bought the bike from works for a wrap company. I inquired about side wraps, $4k minimum.
01-04-2020, 02:56 AM
#376
Rated Cap: me + 1
How big of a bus will 4K cover?
01-04-2020, 05:23 AM
#377
I wana do a basic white paint job with lots of green accents.
AND get some areas done by a few local taggers I've gotten to know.
A LONG line of brand new box cars was brought into town a month ago. YOu wouldn't believe the quality of graffiti we're seeing here. Truly artwork!
01-04-2020, 11:03 AM
#378
That is about the same quote that I got from an outfit in Seattle to wrap a six window cutaway.
01-04-2020, 11:44 AM
#379
Rated Cap: 34
My employer's property backs up to a small switching yard, and we have to leave the property to smoke......so at break time I get treated to an art show that changes every couple of days.
01-04-2020, 12:14 PM
#380
Mine's 37'
