Old 01-19-2020, 03:52 PM   #381
plfking's Avatar
Rated Cap: 34
Slowly but surely getting my electricals installed.....have finished all the undercounter and utility area outlets. Hope to finish the splashboards next weekend.
Due to an incident when I was younger, I've shied away from any electrical work since then, and I'm paying the price now.
"It's even money whether I'll finish getting it all in before I electrocute myself" he said with a smile, but also with plenty of internal apprehension.
Don
The Busted Flush
Old 01-19-2020, 10:38 PM   #382
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
I don't blame you on the electrical. It scares me so I respect it. My dad is very good with it and has taught me a lot. But I still stick to the basics. So glad he helped me get everything installed and ran. I have wiring ran and just need to install a few outlets when the interior is finished. Looking good tho! A few outlets go a long ways in a bus!!
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
Frochevy is offline   Reply With Quote
Old 01-20-2020, 05:42 PM   #383
plfking's Avatar
Rated Cap: 34
How much to rent your dad for a week?
Don
The Busted Flush
Old 01-20-2020, 10:38 PM   #384
Frochevy's Avatar
Chassis: Collins
Haha! Kansas is a long ways away from North Carolina and He's a homebody! 😁
Old 02-02-2020, 03:42 PM   #385
plfking's Avatar
Rated Cap: 34
Finished installing the rest of my outlets and running the wiring, which allowed me to finish my splashboards, which allowed me to finish my counter dividers. The small section of counter is my 'integrated' nightstand.
Question for any photographers or astral engineers.....my windows are one of my favorite things about my bus, but I can't get a pic of the way they reflect every color in the spectrum.....has it something to do with the way light is reflected in my phone's camera lens?
Don
The Busted Flush
Old 03-29-2020, 11:33 PM   #386
plfking's Avatar
Rated Cap: 34
Still running wire, but the finish line is in sight. Built a door on the interior side of my genny cabinet for access from both sides.....hope to have my gen and battery set-up done by end of April.
My cabinet "double-doors' were starting to sag from their own weight, so I made them lighter. And no luck in finding small enough fridges and freezers to fit in my cabinets, so will need to cut one of my counter tops and re-work it. (I did find some 'Igloo' types that would work, but I'm not spending $4-500 on one).
Had a rear turn signal go bad, so replaced them both. Then I noticed that most of my marker light lenses had holes burned in them from the bulb heat, so replaced all of those as well.......lenses were only $2 each from A Parts Warehouse.
Also made bracket templates for my rear deck/porch.
Don
The Busted Flush
Old 04-04-2020, 07:43 PM   #387
plfking's Avatar
Rated Cap: 34
Needed a break from wiring, so I jumped to my rear deck project. I wanted something easily dis-assembled in case I ran across a strictly-enforced 25' limit, as light as possible, but also strong enough to haul around a 200-250 cc dual sport bike eventually (mountain bike for now). Also plan to leave the middle section of the deck open (or maybe hinged to fold down) to allow access to my rear inside storage.
All the steel, bolts, and braces were about $125 total. The holes in the braces matched up perfectly with the perforated tubes. The 1 1/4" tube will be welded to the flat plates, which will be permanently bolted on via longer bumper bolts and spacers. Drop in the 1" tubes and lock in with lynch pins. Will get everything welded, cleaned up, and painted this week, and mount it next weekend. Then cover it with 1" planks.
All good workshirts must eventually be retired....this one went out in a (literal) blaze of glory while cutting with the angle grinder. I thought the stomach pain was just a bad hot dog, 'til I looked down and saw the flames.
Don
The Busted Flush
Old 04-04-2020, 07:46 PM   #388
Gettin her done! Great to see you're still goin strong at it Don.
Old 04-04-2020, 07:51 PM   #389
plfking's Avatar
Rated Cap: 34
The wiring is soooooooo tedious......I needed something fun to keep my enthusiasm up.
Don
The Busted Flush
Old 04-04-2020, 07:52 PM   #390
Looking good, man. I guess so many people have been saying "self-immolation" when they mean "self-isolation" it was bound to happen to one of us. So far on this project I've only ignited myself indirectly, by first igniting the lawn my leg was lying in.
Old 04-04-2020, 10:06 PM   #391
Frochevy's Avatar
Chassis: Collins
A little duct tape over the hole in the shirt and you'll be back at it!!! Can't wait to see how the rear deck turns out!
Old 04-05-2020, 10:44 AM   #392
plfking's Avatar
Rated Cap: 34
You, me, dozens of Buddhist monks and hundreds of protesters.......but I think you're the only one that set the grass on fire.
Don
The Busted Flush
Old 04-05-2020, 11:02 AM   #393
plfking's Avatar
Rated Cap: 34
One of these days we'll find something that duct tape CAN'T fix......probably not in my lifetime, though.
Don
The Busted Flush
Old 04-07-2020, 06:29 PM   #394
plfking's Avatar
Rated Cap: 34
Got my rear deck built.....will let it air out for a few days, then sand and urethane this weekend.
A friend bet me 1" perforated tube wouldn't hold a dirt bike without deflecting (i weigh 240).
Also picked up one of those Harbor Freight 2500lb ATV winches....will be mounting it on the roof deck to lift my (future) dual sport.
Don
The Busted Flush
Old 04-07-2020, 07:19 PM   #395
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
This makes me want a rear deck. Thanks for the ideas.
JDSquared is offline   Reply With Quote
Old 04-07-2020, 07:23 PM   #396
Frochevy's Avatar
Chassis: Collins
That looks great!!!! What type of dual sport are you planning on getting? I'm on my 3rd one right now... It's an older KLR650... A bit heavier than my last one but a comfortable ride...
Old 04-07-2020, 11:15 PM   #397
plfking's Avatar
Rated Cap: 34
As small as possible.....given my fat-ass status, that probably means a 250. I'll buy a used one by any of the Big 3 in a couple of years. I don't need speed, just a mule to scout out forestry service roads, prospecting forays, and the occasional jaunt into town for supplies.
Don
The Busted Flush
Old 04-08-2020, 06:49 AM   #398
Frochevy's Avatar
Chassis: Collins
That sounds like a good plan! A 250 would be perfect for that. When I built my platform I had a Suzuki DRZ400 and had planned to do the same. Lol never got around to making long trips in the bus tho because I haven't finished it yet!! Keep up your good progress!!
Old 04-09-2020, 12:35 PM   #399
THANK YOU for posting the photos of your deck! I've been fretting over how to build one on my bumper, and I was about to do it the wrong way... now I see there is a simple elegant solution! It looks great, I'll post up when I finish mine.
TheArgobus is offline   Reply With Quote
Old 04-09-2020, 05:04 PM   #400
plfking's Avatar
Rated Cap: 34
No problem......I got the idea from this video. If you're building it as permanent, definitely go his way with the triangular bracing. His is much deeper and stronger......but I can dis-assemble mine and throw it in the rear storage area in about 2 minutes, without any tools.
You'll need slightly longer bumper bolts.
Don
The Busted Flush
