Old 02-10-2019, 08:06 PM   #231
Engine: t444e
I identify as a solar panel
What angle did you cut the bottom of the joists?
ChiliChzPoopTart is offline   Reply With Quote
Old 02-10-2019, 09:08 PM   #232
plfking's Avatar
Rated Cap: 34
Well, then, feel free to climb on up there......and don't forget your beer.
No angle.......I put 3/8" thick weatherstripping on the outside edges of the joists, and bent the brackets slightly so that they were perpendicular to the centerline plane of the roof, then shimmed the inside edges of the joists 1/16", then bolted the joists on, then removed the shims. The inside edges ended up just above the roof, so that water can't get trapped against the wood and start the rotting process. The joists also got painted and urethaned beforehand.
Don
The Busted Flush
Old 02-11-2019, 10:57 AM   #233
Engine: t444e
did you use 5/4 board or just standard decking? weight estimate?
you need a plug up there for a blender.
Old 02-11-2019, 02:24 PM   #234
desertfather's Avatar
Coachwork: Wayne Lifeguard
Hey man, this looks great! Another quick question about your roof deck. You mentioned that you used bolts instead of screws, which makes sense. But how does it work on the inside? Are the bolts going all the way through your roof and into the interior, where each one is held on with a nut and washer?
I've been working on my six-window too, but it's been all interior stuff during the winter...I'm passing the time otherwise figuring out my roof deck build plan for the spring, so this is good info!
desertfather is offline   Reply With Quote
Old 02-11-2019, 03:47 PM   #235
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
Originally Posted by plfking View Post
Are you going to put any kind of handle on the door?
Just a pull handle. I've just been grabbing the space under the door and pulling... I have the handle to install.
Nick
Old 02-11-2019, 05:03 PM   #236
Clean set up the way you have it. Do you really need a handle? The door pops open a bit anyways once you unlock, right?
Old 02-11-2019, 05:06 PM   #237
Ninjakitty's Avatar
It needs a little tug to open. Think its the weather stripping. I'm not going in and out of there a lot at this point so I'll probably put it off until more important things are finished.
Nick
Old 02-11-2019, 07:55 PM   #238
plfking's Avatar
Rated Cap: 34
1" was my original thought, but went with 3/4" pine for weight savings. The deck is 6' wide.....thought if I went 8' I'd be more likely to snag a tree limb or worse. Weight? I'd guess around 200 pounds or so total.
Stop adding to my To-Do list! I was gonna have 1 plug for a radio, but if I add another for a blender, then I gotta build a dumbwaiter to get the liquor, ice, drink mix, munchies, etc. upstairs.
Don
The Busted Flush
Old 02-11-2019, 08:10 PM   #239
plfking's Avatar
Rated Cap: 34
Was wondering where you were on your build.....haven't seen any updates in a while.
Just as you said.....bolts running through the FLANGE of the roof ribs. Tried 3/8" bolts to start, but keeping the holes inside the width of the 1/2" flange was not leaving me enough room to get the washer and lock nuts on (bolts were too close to the ribs), so I dropped down to 5/16".
Used locking pliers to hold the nuts while tightening from the roof. I envy you all your boys......extra hands whenever you need them.
Don
The Busted Flush
Old 02-13-2019, 06:35 AM   #240
Ah, that makes sense and sounds like a really solid way to do it. But you're doing a much more thorough build than me -- I haven't taken the ceiling skins off (and don't plan to), so I don't know, I might have to go all the way through the ceiling and have bolts sticking into the interior. :/ Gonna have to think about that, and whether there are any decent alternatives.
I'll get photos up soon from my continued build...been working on the "living room," i.e. the 5 feet behind the driver's seat!
