Old 01-05-2018, 09:53 PM   #51
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
That is awsome, finally ay.? That smile say's it all, one step closer. First step gut it.?
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 01-05-2018, 10:15 PM   #52
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
Yeah. We didn't do that on my shuttle bus so we've been fighting the heat on our trips the last several summers. I'll have to get some pictures of that one sometime..
This should be a lot easier to keep a comfortable temperature being so small.
Thomas1985 is offline   Reply With Quote
Old 01-06-2018, 02:23 AM   #53
Are you planning on putting better insulation in the walls.?
I was battling the cold on the trip to Colorado with no insulation at all, up all night but worth it. Is it not possible to sit on the passenger side with a removable floor cover in the entry door.?
Blue Sky's
Old 01-07-2018, 01:22 AM   #54
Thomas1985's Avatar
I need to leave that space open for people to come and go. I use a 4 point tie down strap system in the floor to keep me from moving while we drive.
For the walls and ceiling I want to cover all my bases: conductive, convective, and radiative heat. I don't know why but I don't think I've seen anyone do it like this guy..
Inside Exterior Walls - Hot/Mixed Climates - AtticFoil® Radiant Barrier - Do-It-Yourself Professional Grade Radiant Barrier
I've been reading the forum for a while but I don't remember coming across any builds like this. If any of you guys know any please send me a link.
That's my plan. Creating the air gap for the radiant heat.
This last July 29 we were camping in South Texas near the White Water Amphitheater where we saw Slighty Stoopid and it was over 110°a couple of days. One night we thew all the doors open including the wheelchair lift and the windows while running fans and couldn't sleep we were so hot. This bus we're gonna work hard on getting insulated and using a window unit.
Fun times though. There's a great place called Kraus springs to cool off at and camp.
People choosing to live in Texas are obviously nuts! I admit I do enjoy a good endurance trial from time to time
Old 01-07-2018, 02:35 AM   #55
Chassis: Saf-T-Liner MVP ER
I think you need to research that foil carefully.
In a home situation, and especially in an attic, it works because of the large air-space. I have heard of others using it in a Skoolie, but not with anything like those results.
They claim a tremendous R-Value as part of an installation, but there appears to be very little other than their claims to back it up.
You may have seen research I have missed, but I'd hate for you to be disappointed.
Steve Bracken
Build Thread
Old 01-07-2018, 06:19 PM   #56
Thomas1985's Avatar
I found some other sites that were specific to constructing metal buildings that also recommend having an air gap for radiant heat. Any of these aluminum foil products will work for reflecting that while my polystyrene (XPS) insulation does the rest of the work for conductive and convective applications.
https://www.ecofoil.com/metal-building-insulation
So instead of filling the wall panels I'm going to leave them as my dead air space after making sure it's airtight. Then put furing strips with foil stapled over that, foam board insulation, and then the inner wall. I decided I'm not worried about losing several inches of interior width because my bed has more than a foot of wiggle room between the walls anyway.
Old 01-07-2018, 06:36 PM   #57
Defjr333's Avatar
Chassis: Shuttle or Shorty. Still hunting
Engine: Prefer Diesel
Rated Cap: 14 to 24 pref
Im torn on this topic/ subject. I have yet to see a cooler or fridge with an air gap before the insulation. Plastic or metal, they all seem to be solid foam sandwiched between the inside and outside layers(plastic or metal). In a house, yeah. You can get as much as 6" gap. But when the majority of us need every inch of space possible, I think I am going to forgo the "air gap". Unless I learn something definitive and provable. Never know....
Doug
Defjr333 is offline   Reply With Quote
Old 01-07-2018, 07:30 PM   #58
Most folk line out their buses so that the wall sits on the edge of the protrusion on the chair rail. So you lose no more than about 3" of the standard 96" interior width.
Helpfully, that gives about three inches of space, each side, to fill with insulation and services (water and electrical).
If you can get close to 3" of foamboard or spray foam in there, you will not be unhappy with the result.
Steve Bracken
Build Thread
Old 03-03-2018, 09:22 PM   #59
Thomas1985's Avatar
It was finally in the fifties today and not raining like it has been for the last two weeks so my friend Eugene helped get the seats and floor ripped out.
Nothing major. Several holes from screws that went too far through the plywood and one small rust whole in the back driver side corner.
My friends at Unique Creations in Fayetteville are letting me keep it there in the corner of the parking lot and run an extension cord for my tools. They are awesome. We've built several metal sculptures together over the last several years and they will do engine work and any metal fabrication we can manage ourselves. It's a great spot to work on a project like this. If anyone even near the area needs and metal fabrication or automotive work they are the guys to go to. They'll build anything.
Also we noticed the inside isn't rivets it's hex screws so the impact drill will make it easy work of it!
If the rain will stay away it's the right time of year to start getting it done. Great weather.
Old 04-12-2018, 08:38 PM   #60
Thomas1985's Avatar
This is the end of this thread. The build is being moved here.
- Thomas
The Daily Driver Bus Build
