Old 04-12-2018, 07:06 PM   #1
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
The Daily Driver Bus Build
This is my 1991 GMC Carpenter Clipper. They were built from 1985 to 1991. Not many were produced due to the demand of class C and D buses.
In May 1991, Carpenter purchased the tooling, product rights, and intellectual property of Crown Coach and from 1992 to 1998 rebranded the style from the GMC Vandura Chassis to the Chevrolet Express/GMC Savana known as the "Carpenter/Crown by Carpenter Classmate" and the "Crown by Carpenter Commuter (commercial)" before ending production of type A buses altogether.
The demolition has been done. I'm starting this fresh thread specifically for the building of the Daily Driver Bus.
If you're interested in everything leading up to the purchase you can find it here.
- Thomas
Thomas1985 is offline   Reply With Quote
Old 04-12-2018, 07:09 PM   #2
Thomas1985's Avatar
Here's a couple pictures of the bus gutted:
- Thomas
Old 04-12-2018, 07:13 PM   #3
Thomas1985's Avatar
Then with the help of our friends at Unique Creations we began raising the roof:
- Thomas
Old 04-12-2018, 07:18 PM   #4
Johnny Mullet's Avatar
Engine: T444E 7.3L
That is awesome! Following this build!
Old 04-12-2018, 07:35 PM   #5
Thomas1985's Avatar
The first picture shows 1 X 3 inch square tubing clamped to the ribs. It was tack welded on the portion below the window for temporary reliable stabilization. This was done in four corners.
The next picture shows the top clamps removed and 2 tall screws jacks being turned at the same time lifting the roof.
The third and fourth pictures show our desired height reached at 15 inches and the top clamps reapplied. At this point we put 1 inch square tubing inside the hollow bus ribs and secured it with a few self taping screws up above and below our new gap.
At this point the original 1 X 3 was cut off no longer needed.
Next we removed the back windows and the lower row of rivets above the windows where we will slide the new sheet metal into before replacing the rivets. I guess we didn't end up getting pictures of that.
The 1 inch square tubing will be supported on both sides by two more identical pieces running from floor to ceiling to make it structurally sound. A combination of welds and rivets will hold it together.
- Thomas
Old 04-12-2018, 10:12 PM   #6
Year: 1980
Chassis: Chevrolet
Engine: Small Block Chevrolet. May swap out for ?
Awesome job, I can't wait to see how it comes together.
Mack
Coamack1 is offline   Reply With Quote
Old 04-13-2018, 01:56 PM   #7
THIS is one I want to follow!
toplessartist is offline   Reply With Quote
Old 05-31-2018, 06:59 PM   #8
Thomas1985's Avatar
We've been a little busy for the last month and fighting the rain on the days we try to come out but finally got a couple days in at the shop. It's all framed up now and supported with more 1 inch square tubing on either side of each rib and a few in each back corner welded at spots from the floor to the top of the window edge. The second picture is my passenger side window framing which will be at the head of the bed.
One other large window will go on the driver's side but it hasn't arrived yet so we'll have to wait on framing that one.
We should be able to get back over there tomorrow and hopefully make a little more progress. Just purchased a new impact drill from Harbor Freight on sale pretty cheap. We'll need to use that to drill all the rivet holes at the top of our new skin above the window. That's our next step. After that we'll cut the exact window hole in line with our frame, hit it with primer, permanently put it up and finally get the window sealed in place!
- Thomas
Old 05-31-2018, 07:18 PM   #9
Chassis: Chevy G30
Engine: 5.7L
I'm looking forward to following along with this build! Things are looking really good. What was the approximate ceiling height before the lift and what will you end up with after?
BagelBus is offline   Reply With Quote
Old 05-31-2018, 08:15 PM   #10
Thomas1985's Avatar
It started at 6ft head clearance but after insulating would have been more like 5 foot 8 inches which wasn't going to work. We raised it 15 inches which now I think may be a little overkill but that will give us a 7 foot ceiling with 3 inches of insulation in the roof above that. Another reason I wanted 7 foot is because after this is built I'm going to be engineering an overhead track system with some sort of custom built sling so that my girlfriend can get me from my wheelchair to the bed and back without breaking her back. This is going to be pivotal the older we get. I'll also be working on a transfer system that attaches to wheelchairs instead of your old outdated hoyer lifts that take up so much floor space. I'm hoping to be able to help a lot of people out developing this. Fingers crossed.
- Thomas
Old 05-31-2018, 08:20 PM   #11
neat stuff.. first time ive seen a roof raise on a cutaway.. what made you device to cut it behind the service door vs separate the bus from the van at the front?
Old 05-31-2018, 09:00 PM   #12
Thomas1985's Avatar
Well it looks like from the driver's side we can cut that whole roof cap off neatly and raise the whole thing evenly but once we gutted it it was apparent that the front cap above the windshield would be a problem to cut because of how all the supports are built. Also, it's a lot easier leaving the folding door frame untouched. The transition piece to connect the raised section to the front is going to work out nicely as a large storage spot over all the drivers area. Sort of a large pocket if you think of it like that which will be a huge bonus in such a short vehicle.
- Thomas
Old 05-31-2018, 09:07 PM   #13
Nice.
need MOAR pics though!
Old 05-31-2018, 09:13 PM   #14
Thomas1985's Avatar
Yea I always end up getting them at the end of the work day when the sun is going down. I'll try in the morning next time when the lighting is better behind the shop.
- Thomas
Old 05-31-2018, 09:19 PM   #15
Nice on raising the shorty roof!
Old 06-01-2018, 06:09 AM   #16
Chassis: Chevy G30
Engine: 5.7L
Sounds like a good plan, very cool!
Old 06-01-2018, 07:43 AM   #17
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Fantastick..
Old 06-08-2018, 01:21 PM   #18
I'm VERY interested in following this!
Old 07-12-2018, 10:32 PM   #19
I LOVE this!
Love the extra ceiling height and the way you created it. Great thinking! Following along on the build.
TimJ is offline   Reply With Quote
Old 07-12-2018, 10:41 PM   #20
oricha1984's Avatar
Engine: gasser probably
more pictures plzzzzzzzzzzz
oricha1984 is offline   Reply With Quote
