Old 10-19-2010, 08:02 PM   #101
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Started cutting up some diamond plate for the windows and to cover the holes at the top... Thanks Shane for the plasma assist...
Then started getting some black on it... I still have the other side I'll do tomorrow and paint the diamond plate for the back windows...
dirtygoat is offline   Reply With Quote
Old 10-20-2010, 01:28 PM   #102
Year: 1974
Coachwork: Ward
Engine: 350
Re: The Dirtybus...
I think the last photo is a set of chains designed to be carried in the up position during summer driving and then with the flick of a switch these chains lower in front of the rear wheels and spin as the rear wheels turn to give them better traction in the snow.We carry this system on our ambulances and they work just fine in snow driving.
GreyWolf is offline   Reply With Quote
Old 10-22-2010, 08:33 PM   #103
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Got the passenger side awning installed today... Had to make some small plates to bolt to on the inside... Still have to install the driver side awning...
Old 10-22-2010, 10:30 PM   #104
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: The Dirtybus...
OK I am jealous, I have been looking for an awning for a minute and cant find one....at a decent price that is
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 10-22-2010, 11:04 PM   #105
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
I've got a 12' one for the other side...
Look at craigslist for cheap bumper pull camp trailers... You can get everything you need out of buying just one... Then scrap the rest and use the frame and axles to build a small utility trailer...
I picked up the 21' that you see in the pic at an RV salvage yard up here for $120 I think... And got the 12' awning for the other side from a neighbor for $25...
Old 10-23-2010, 02:10 PM   #106
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: The Dirtybus...
My parts trailer awning is junk. I think I hate you.
Jarlaxle
Old 10-26-2010, 04:21 PM   #107
Year: 1987
Chassis: International S1800
Engine: 9.0L International
Rated Cap: 44
Re: The Dirtybus...
Hey dirtygoat,
The valve cover on your int diesel looks more like a dt360 rather than a dt466, have you checked this? If I remember correctly the dt360 has all raised ribs in the valve cover, where th dt466 has alternating raised and recessed ribs. I could be wrong though. The conversion looks great!!
lemitar is offline   Reply With Quote
Old 10-29-2010, 06:43 PM   #108
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Originally Posted by lemitar
Hey dirtygoat,
After I read this I researched a bit and found out that it is indeed a DTA360 190hp in the bus...
What's the pros and cons having a dta360 rather than a dt466???
It appears that it is a mechanical fuel injection and it has an aftercooler...
I also found between the rails complete rebuild kits for under $1000... Nothing wrong with mine, but that price seems very reasonable...
Old 10-30-2010, 11:04 PM   #109
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Dirtybus...
You should get 10mpg as opposed to the 8mpg you would expect from the DT466. Less power of course, but I've heard good things about that engine. I thought it seemed odd to have a DT466 in a shorty! You'll be glad you have mechanical injection if you ever have to replace injectors. Much cheaper!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-30-2010, 11:11 PM   #110
opus's Avatar
Chassis: All-American R/E
Re: The Dirtybus...
I drove one for a bunch of years bad never had any issues with them. We had those, 9 liters and 466's. I actually liked the 9's.
