Old 11-01-2010, 05:05 PM   #111
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: The Dirtybus...
The problem being that most DT360's will have the AT545 non-lockup automatic transmission, while the DT466 will usually have the stronger MT643, which DOES lock up. The transmission slippage will more than negate any fuel savings of the smaller engine.
Jarlaxle
Old 11-05-2010, 06:42 PM   #112
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
I got the diamond plate in the window holes and most of the front bolted back together... Still have to paint the grill and the pieces of diamond plate that will cover the holes up top front and back...
Hopefully I'll be able to get down to do emissions and get the plates for it really soon...
dirtygoat is offline   Reply With Quote
Old 11-05-2010, 10:24 PM   #113
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Here's the WOW Trail Fund sticker that will be going up for sale next week... They will be $5, with $4 going to the fund... This fund will be used for trail building projects... I'll post the info when we get the stickers back...
Old 11-06-2010, 12:06 AM   #114
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: The Dirtybus...
very nice!
Old 11-09-2010, 11:35 AM   #115
Year: 1987
Chassis: International S1800
Engine: 9.0L International
Rated Cap: 44
Re: The Dirtybus...
Dirtygoat
There are no downsides to the dta360 (only the transmission), it is a sleeved engine, so an in-frame rebuid is possible as well. Windows look good.
lemitar is offline   Reply With Quote
Old 11-09-2010, 05:00 PM   #116
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Thanks...
I've been reading up on the DTA360 and I feel that I'll be fine... I would like to find out if I can install a lock up on the converter though... They do it on th400s and th350s all the time...
Old 11-10-2010, 07:03 PM   #117
Engine: DT466/MT643
Re: The Dirtybus...
Would probably be easier to just swap the whole trans for an MT643. The DT360 should use the same bellhousing bolt pattern as the DT466 and the MT643 was used in the same chassis, so the swap should be simple enough.
Jarlaxle
Old 12-02-2010, 09:19 AM   #118
zim
zim's Avatar
Year: 82
Chassis: TransitLiner
Engine: Cummins 5.9l
Re: The Dirtybus...
So tell us about the paint? Anything special? I'm looking to do the same color on my transit liner.
Project Blog @ TechnoVardo.com
zim is offline   Reply With Quote
Old 12-03-2010, 04:54 PM   #119
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
The paint was from a friend... They use it to paint Freightliner Semi's... He had it tinted for me and gave me the catalyst(hardener) for it... I went to a paint shop and picked up the reducer and shot it on with a harbor Freight HVLP gravity feed sprayer... It would have been really expensive if I hadn't gotten it for free...
Old 12-03-2010, 05:00 PM   #120
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
OK, I've been bouncing around ideas for the bunks...
I've looked at a ton of other builds and then something clicked...
I'm gonna use black pipe and build a frame, basically posts on all four corners and sockets that the bed rails will drop into... I plan on using Army cots in between the bed rails... This should be easy to set up and take down as needed for hauling equipment...
Here's the cot material that I'm looking at...
