Old 03-05-2012, 03:09 PM   #221
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Test fitting wall panels after carpet was glued on... Now have to cut carpet transition strip to length to cover the seams...
dirtygoat is offline   Reply With Quote
Old 03-05-2012, 03:44 PM   #222
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
At the top you can see how the wiring loom goes on and you can get an idea of the sofa/bunk will work out...
Old 03-05-2012, 04:17 PM   #223
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Here's the carpet transition strip I picked up... Came in 12' sticks... I had to drill the holes bigger so I could use #8 pan head sheet metal screws... You can also see the counter top color and some sticker goo I still need to clean off...
Old 03-05-2012, 05:04 PM   #224
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Got the strips in and the trim for the window... Need to start on the other side now... Then install the bunks and carpet them... It's getting cozy...
Old 03-05-2012, 07:00 PM   #225
Re: The Dirtybus...
Lookin' Good! Carpet sure soaks up a lot of sound too.
Old 03-05-2012, 07:24 PM   #226
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: The Dirtybus...
Grey carpet works for me!
Old 03-05-2012, 08:05 PM   #227
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
The sound is already changing with just that little bit done...
The ceiling will get carpet down the road...
Old 03-07-2012, 12:27 PM   #228
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Started on the other side...
Old 03-07-2012, 05:36 PM   #229
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
You can see the damage to the counter top on the top of the back splash in the last pic... It about 4" long right next to the extension cord..
Old 03-08-2012, 08:21 AM   #230
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Dirtybus...
That carpet will be nice for noise reduction and just overall "coziness", but I hope you have a good portable vacuum cleaner! I don't know about anyone else, but my bus is a dust magnet.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
