Old 09-07-2011, 10:07 AM   #161
newtoskool's Avatar
Re: The Dirtybus...
Maybe it is in the post somewhere but I don't remember. What is the length from behind driver seat to the back door?
newtoskool is offline   Reply With Quote
Old 09-12-2011, 11:16 PM   #162
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
20'...
Haven't touched it in a while...
We finally got some summer weather up here and been cramming as much fun into whatever time we have...
I did get some materials donated from some buddies... A bunch of sch 40 to frame out the bunks, a good bit of 1" angle iron and 1" square tube for framing the galley and a few used aluminum diamond plate truck boxes that will get cut up for cabinet doors...
I need to get back on this thing and get some real progress done... We've been camping a lot and I'd love to have the bus further along, but when the weather is so nice it's hard to not have fun...
dirtygoat is offline   Reply With Quote
Old 09-20-2011, 06:10 PM   #163
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
We took it to a friends house this last weekend to welcome a family friend back from Iraq... Had a great time and stayed the night in the bus... I had it up to 68 mph on flat ground... Also took it to the store to get groceries... It gets more rubber necking than anything I've ever driven...
On Monday I was taking it down to run it through emissions and it went to **** right in front of the bay as I was pulling in... Leadfoot067 came to save my ass and pull it out of the emissions lot... Ended up draining the tank and fuel filter... The fuel looked a bit funky and didn't smell right... Put some fresh stuff in and primed the fuel system and it runs great...
Did find out on Mountain HWY that it runs out of diesel at 1/4 tank on the gauge... Better to find that out close to home than 100 miles away... It needs about 8 gallons in the tank to get the pick-up wet...
Old 10-02-2011, 06:48 PM   #164
TygerCub's Avatar
Engine: Detroit
Re: The Dirtybus...
Just wanted to say I'm absolutely in love with your model of bus. There's one around here used by the school system that I'm eagerly waiting to go out of service.
Do you happen to know your MPG? Just curious if it's any better or worse than a full sized bus.
Old 10-03-2011, 08:05 AM   #165
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Dirtybus...
Yeah, I'm also a big fan of that style bus. Very good use of space and I'm guessing great maneuverability. How does it ride?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-04-2011, 05:17 PM   #166
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Not sure yet on mpg... It rides a bit bumpy but drives nice... I can park it just about anywhere, it very nimble for a bus...
Old 10-07-2011, 06:23 PM   #167
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: The Dirtybus...
the chains are for snow they drop down to help you get your footing on ice,,my fire truck has them,you may have a laver to let them down or a switch,,they are good to have and i would leave them on there,if not ill take them and pay for shipping to me
keith
keith is offline   Reply With Quote
Old 10-08-2011, 09:48 PM   #168
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Yeah, I've played with the chains a little bit already... Onstar charges $2200 for them...
I got part of the dinette and galley framed in today... Pics to come...
Old 10-08-2011, 09:56 PM   #169
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Got some work done on the dinette and galley today...
There will be a 1" thick piece of plywood on the bench and the rest will get treated with aluminum diamond plate...
Old 10-08-2011, 10:12 PM   #170
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Here's the start of the galley... The stove will slide into the open square spot... Still needs a few pieces added on, but you get the idea... Gonna get painted black and aluminum diamond plate for cabinet doors... Then it'll get a slate counter top...
Old 10-10-2011, 02:31 PM   #171
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Got the other seat for the dinette done... Need to do some grinding, weld some nuts on the inside of the square tube to fasten the diamond plate and paint...
Also got the toe kick installed on the galley and started cutting materials for the hearth under the wood stove, but ran out of welding gas...
Gonna start cutting and mocking up the bunk material...
The aluminum tool box is there for mock up of the fridge... It'll be cut up for use as cabinet doors...
Old 10-12-2011, 02:51 PM   #172
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Got the stove mounts welded to the galley... Had to work under the awning because of the rain... The fridge is mocked up... Now I'm gonna work on the upper cabinets...
Old 10-12-2011, 04:21 PM   #173
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: The Dirtybus...
jealous, I want an awning, looking good
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 10-13-2011, 12:51 AM   #174
Coachwork: Ford Eldorado / Aerotech
Chassis: E350
Engine: Ford 7.3 Gasoline
Rated Cap: 11
Re: The Dirtybus...
Looks great cant wait to see the results!
If the women don't find you handsome they should at least find you handy. ~ Red Green
ptooti is offline   Reply With Quote
Old 10-13-2011, 12:57 PM   #175
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Thanks for the comments guys...
Got the rough in done on the upper cabinets... There's another one above the large window on the passenger side as well...
Started the rough framing for the head... I'll try and get some better pics...
Still have a lot of framing to do, but the main structures are coming along nicely... Gonna be a lot of little things that don't show a whole lot of progress happening real soon...
Old 10-13-2011, 09:43 PM   #176
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Here's some better lighted pics...
Pulled the galley out to add a little more...
Then added some diamond plate above the cabinet doors...
Old 10-13-2011, 10:46 PM   #177
Re: The Dirtybus...
Like the wood burner...just wish I had space to keep mine.
Old 10-14-2011, 12:28 PM   #178
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
I only have 20' of living space behind the driver seat... Spent way to much time drawing up floor plans to make everything work... I knew that the galley and the head had to go where they are based on black and grey tanks, the passenger side was already taken up by the fuel tank... As soon as I started building and setting things in place, it was easier to fit everything else...
Old 10-14-2011, 03:21 PM   #179
Re: The Dirtybus...
That's twice the room I have...and the reason I'm adding on a "back porch" and roof rack. Gotta' be really frugal (and creative) with my space usage. But then there's a reason why they are called "Shorties", right.
Old 10-15-2011, 01:12 PM   #180
Engine: DTA360
Rated Cap: 16
Re: The Dirtybus...
Yours would be more like a mini...
