Old 06-20-2015, 12:00 PM   #221
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Hey, everyone!
This is my train of thought for the floor: after I spray more ospho and rustoleum on the inside and about 2" around, I was going to apply something similar to epoxy to coat the whole floor, plug the holes from the seats, level and give more thickness to the sheet metal as it is a bit thin in some spots from rust. Looks like a material like the epoxy for garage coating is too thin, and it would run through the holes. But then I thought "what if I stick some type of a mesh on the floor first, then apply the epoxy?"
The idea here is to keep the overall thickness of the floor to a minimum, as I want to add soundproofing layer and self-sticky tiles for finish.
So final floor inside would be: metal, rust treatment coating, epoxy or this > http://m.homedepot.com/p/BEHR-Premiu...801/204166284/ layered enough to plug holes from seats and other screws, then sound and vibration reducer > http://m.homedepot.com/p/4-ft-x-8-ft...6BX/100663624/ , then regular sticky tiles.
What do you all think? Be gentle....
Disclaimer: i posted h-d links only because it's 5 minutes away from the house, not intended as publicity or soliciting in any way. I've also gone to Lowes and ace hw many times
And BTW posting from phone, so let me know if the URLs get messed up in the interwebz
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 07-19-2015, 11:11 AM   #222
Coachwork: Ward
I've found the mesh I'll be using to cover the holes and pour the coat! We're in business! Some testing before 100% deployment ;)
Bought so far for skoolie:
1. Marker lights
2.Replacement headlights
3. Water pump (yes!!!)
Next are new side mirrors (think I found some good ones), and a storage unit to replace the battery compartment as it is all rusted up.
This will be slightly longer to fit right between the underbelly supports. I can't wait to start cutting!
Old 07-19-2015, 11:20 AM   #223
1. Marker lights
I didn't follow your previous links.... but something like this might help your cause also.
https://www.google.com/search?q=fibe...utf-8&oe=utf-8
it's sticky and easy peasy to work with
Old 07-31-2015, 04:03 PM   #224
COOL BUS! Im also from florida, x miamian moved to Georgia. im looking at one right now for $1500
THE-LAZOS is offline   Reply With Quote
Old 07-31-2015, 05:57 PM   #225
Coachwork: IC
Chassis: CE300
Rated Cap: 32
There are several of us Floridians on here!
Old 07-31-2015, 06:00 PM   #226
Chassis: MVP
Engine: CAT 3116
Miami in the house right here!
Piersg is offline   Reply With Quote
Old 07-31-2015, 07:27 PM   #227
Yeah I'm following your thread I'm looking at a bus just like yoursImageUploadedByTapatalk1438388804.657134.jpg
Old 07-31-2015, 08:01 PM   #228
Coachwork: Ward
That looks awesome! And thank you
Hoping to start the "heavy duty" work soon. Just got my water pump! Soooo excited!
Old 07-31-2015, 08:03 PM   #229
Coachwork: Ward
Originally Posted by milkmania View Post
i didn't follow your previous links.... But something like this might help your cause also.
yes! Even better!
Old 08-01-2015, 08:02 AM   #230
Chassis: MVP
Engine: CAT 3116
I'm going to use roof tin caps to patch the holes in my floor. A little dab of epoxy or some sort of adhesive sealer and one of these should patch the hole with out adding any significant thickness...
Grip-Rite 1 lb. Tin Caps-TIN1 - The Home Depot
