Old 04-17-2016, 10:15 AM   #341
Robin97396's Avatar
Several other people removed the bifold bus doors and welded them so it functions as one big door that opens outward. Same idea of keeping the bus look and the high amount of visibility through all that glass.
Old 04-17-2016, 10:34 AM   #342
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Yeah... That way it would be perfect...but we didn't want to lose the "old school" arm/guide action. Being from overseas, I've never rode one of these, and it's part of the charm for me.
Makes sense?
Sent from my Nexus 6 using Tapatalk
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 04-17-2016, 11:55 AM   #343
Chassis: International S3800
Makes sense?
im not from overseas.. but part of the charm for me too is making it "FEEL" still like a school bus..
in my case thats one reason I bought an older bus.. I wanted the old industrial-metal feel to the dashboard and driver area too (as opposed to the more car-like dashboards of the newer busses)..
why do you have to lock the front door? if you push it fully closed and latched doesnt that make it where it cant be pushed open from outside? then you can exit the bus from the rear door and lock it with a key..
or is it mainly from inconvenience of no stairs in back or will you have furniture / fixtures covering that door?
Old 04-17-2016, 11:57 AM   #344
Robin97396's Avatar
Even if the door is one piece, you can still attach the manual door closing mechanism. That is something I like about the older buses because the front door is secured from inside the bus.
The other people that reconstructed the doors into one door used the same door closing and opening mechanism, but adjusted a bit. At least one of them was still on air controls. There's no reason why you couldn't still control the door with the manual open/closing mechanism.
Old 04-17-2016, 12:21 PM   #345
Robin97396's Avatar
My front air doors only lock from the outside and there is no latch to keep them closed if it's not locked from the outside, so I often tie them closed with paracord. When there is no air pressure you can easily pull open the door, and at times the wind will open the door at night. In cold weather I do lock the front door from the outside and use the rear door for entry/exit. The problem is the rear door and the wheel chair door only lock from the inside, so when you're leaving the bus it's natural to lock the back doors with the barrel bolts first then lock the front door as you're exiting.
When I'm staying in the bus I need to secure the front door from the inside because it won't stay closed, and I've been paying particular attention to how the deadbolts are being installed on the doors in other builds. I've gotten some good ideas, but I still need to get off my arse to make it happen. I'm dealing with a lot of other little things right now so the deadbolts will have to wait. Luckily I live far out in the boonies so there's not much security risk. Hey, I'm boondocking in my own driveway.
I've had the old industrial metal feel on my previous four buses. There are advantages, such as being able to secure the door when you're inside. At the same time it is possible to lock yourself out under the right conditions with manual doors.
I'm pretty tickled with my air doors in this bus, at least until it starts having problems. It locks up well when I'm in town, with the exception of the top hatch. It shouldn't take to much to make some kind of cornpone latch to secure that hatch.
Honestly I enjoyed driving a class C bus better than a class D.
Old 04-18-2016, 10:34 AM   #346
Coachwork: Ward
I'd like to lock the front door with a more....mundane...system? if that makes sense.
And the inconvenience in the back is another; bed and water tank will be directly in front of the door, so that door will more than likely stay locked at all times. It is, however, nice to have an easy way to lock from inside and outside
Old 04-18-2016, 10:44 AM   #347
Coachwork: Ward
Agreed
I've reverted back to the manual arm/lock mechanism+ existing padlock for exterior lock.
Yes, i can lock the door into place from the inside
I can see myself yanking the door too hard to put the padlock on, and locking the door on both ends!!!
And i'm in the same boat with the deadbolt: after messing with the front door for the better part of saturday afternoon, i though "enough, tomorrow is framing time!". so i put everything back the way it was...and yesterday started framing the bed supports...
Old 04-18-2016, 11:07 AM   #348
Coachwork: Ward
Thanks!
Needed quote for rear lock idea (thanks to FlyBoy for sharing:
http://www.skoolie.net/forums/f33/se...tml#post141863
And also, please don't take it personal or to offense if i don't quote something taken from another post/thread. i don't do it maliciously, i just have "scatter brain syndrome"; i look for something, read it...then apply it a month later, and can't find it again!
And to all, for sharing
Old 04-18-2016, 11:19 AM   #349
Coachwork: Ward
Framing for the bedroom area started:
It wasn't blistering hot yesterday, but I thought "why not be comfortable?"
Old 04-18-2016, 12:10 PM   #350
Hopefully this post isn't too far off topic. I wanted to keep the original look of the door but found the 2 part folding mechanism took up too much of the entry area. I welded the halves together and mounted them on a "parallelogram plug" door actuator from an airporter bus. I put a toggle switch on the dash and a keyed switch on the outside. Jack
Door halves welded together.
Hinge, air pump and tank.
Test fit.
Finished door.
