Old 02-02-2015, 10:37 AM   #31
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I don't know about that stuff. Especially the plumbing.
I'm mounting my tanks low to keep the weight as close to the bottom center as possible for weight distribution.
Old 02-02-2015, 10:47 AM   #32
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
True....but I'm not putting a 200gal tank....I'm thinking less than 100
Sent from my SPH-L710 using Tapatalk
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 02-02-2015, 10:53 AM   #33
Coachwork: IC
Chassis: CE300
Rated Cap: 32
oh, right on. I sort of forgot "weekend camper" part. At around 8.3 lbs per gallon water can get heavy quickly.
If it was me and I were only using it as a weekender, I'd me tempted to use the refillable water jugs with the spout on the front at the sink and would use a solar shower bag. That would save some space. Anyhow, just thinking. Its raining out so I'm extremely bored.
How high you wanna go then?
Old 02-02-2015, 10:59 AM   #34
Coachwork: Ward
I forgot to mention my ideas for grey water disposal! If we go the "no shower" route, then it'll be simple implementation with collection right under the sink, with hose attachment for external disposal when full. If shower is involved.....idk
Old 02-02-2015, 11:11 AM   #35
Coachwork: Ward
Was going to go as high ad the inside of the roof....so about 6ft?
Old 02-02-2015, 05:11 PM   #36
Coachwork: Ford/Champion
Chassis: E-350
Engine: 7.3L PSD
If you are putting any significant amount of liquid that high up you will need baffles in the tank. Otherwise it will slosh around when you're cornering and could cause MAJOR problems. I can go into all the physics if you want to really determine the risk, but for now I'll just say that it would be a much safer bet to keep the center of gravity low and use a submersible pump IMHO. You're not going to get that much pressure anyway unless you have a really big tank up there.
scotticus is offline   Reply With Quote
Old 02-02-2015, 05:47 PM   #37
I have to second the "High Water" concerns. At 8.34 lbs. per gallon it adds up fast ( I will avoid going into inertial effects and moment arms as well). Anything over 4 or five gallons could be an issue. Beyond a number of other considerations, if (when) anything about the tank leaks, it is all coming down and in.
An interior or underbelly tank & pump (electrical or manual) are the standard for quite a few good reasons.
Old 02-02-2015, 06:37 PM   #38
roach711's Avatar
Rated Cap: 19
I put a shower in ours and we have used it exactly three times in two years (partly because I'm a slob). If you're going to be mostly parking at campgrounds with showers you may be able to do without it. Space is very tight in these shorties.
We have a 35 gallon fresh water tank under the bed in ours with a flowjet water pump. You won't get much water pressure with a raised tank.
Old 02-03-2015, 02:32 PM   #39
Coachwork: Ward
@scotticus and @tango I completely agree. Had not thought about those points one bit!
@roach lol and about the tank under the bed. I think we want to use that as storage....what are the dimensions of your 35gal?
Old 02-03-2015, 04:54 PM   #40
roach711's Avatar
Rated Cap: 19
Mine's about 37x19x12 inches. Here it is under the bed early in the construction phase.
