Old 07-03-2015, 08:16 PM   #31
Like I said, I've had and used a lot of different SBC ton trucks and have done a lot of work with them. Just took it for granted that this '91 bus would act the same as my chevy trucks. I've been using my 2012 Dodge 3500 cummins to pull my old cars with, just thought it would be more fun using an old bus from time to time.... Guess I'll have to wait and hook up a trailer to is to see what it will do...Joe.
joetx is offline   Reply With Quote
Old 07-03-2015, 11:02 PM   #32
crazycal's Avatar
Let's go through this. Your Dodge has a lockup converter. My bus does not. Your old cars weigh 3-4000 pounds. My Excursion weighs at least 9000 without all the extra crap I took and my trailer weighs at least 2500 pounds. The GVW of the bus is 23,000 and weighs 16,100 pounds. So I am weighing in at over 27,000 pounds with the Ex on the trailer behind the bus. I could have just pressed on and ignored the temp gauge and dealt with whatever happened in the middle of nowhere. I cross over 7,000 feet at least twice on the way home. My decision was based on caution and nothing else. My bus probably never had more than a couple thousand pounds of students in it. It is in excellent condition, so why ruin it. Every time I hit a small hill, the temp would climb from 180* to over 210*, then the fan clutch would kick on and the temp went down. All this while on the flats of Texas.
I don't know if you are aware of the wonderful split radiator that International uses but I feel it is inadequate for heavy duty use. When I change the trans and radiator to a larger one, I should be able to tow a house without problems.
I'm hungry!
You Gotta Let Me Fly
Old 07-03-2015, 11:18 PM   #33
Ok. Thanks for the explanation. Just don't know enough about the different buses . Just wondered why you had problems with it. Thanks, Joe.
Old 07-03-2015, 11:38 PM   #34
crazycal's Avatar
As far as know, a Turbo 400 has a non-lockup converter. You might want to use a 4L80-E.
I'm hungry!
Old 07-06-2015, 06:29 PM   #35
crazycal's Avatar
Not sure if I sounded snotty in my post. I was not trying too.
I'm hungry!
Old 07-06-2015, 06:32 PM   #36
crazycal's Avatar
And the journey resumes. I fly back to Texas to pick up my tiny weenie bus this week. I hope the A/C won't let me down.
I'm hungry!
Old 07-08-2015, 12:00 AM   #37
This story is seeming more & more backasswards to me. Isn't the bus the thing that moves & not you moving back & forth to it.
You got a great story started and haven't even really taken your bus on the road much to speak of.
At least you can say it gets great gas mileage.
Don't hit me mister I'll be good !!!!!!
The-Breeze is offline   Reply With Quote
Old 07-08-2015, 12:02 AM   #38
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Sounds like day in my life....
M1031A1 is offline   Reply With Quote
Old 07-08-2015, 12:04 AM   #39
How many free miles has she accumulated so far
Maybe you can get enough to get a free bus to travel out to see her every now & then.
(I'm done....naw this story is too much fun)
Old 07-08-2015, 05:16 AM   #40
crazycal's Avatar
Well here I sit at the airport waiting to check my bag. They have free wifi here so I guess I'll do some surfing. I hope I can get a few hours sleep on the plane. No direct flights to Amarillo so I change planes in Dallas. I hope this trip goes nice and smooth. I have only put about 300 miles on the bus. This time I won't be pulling the trailer with the Excursion. My hope is the engine temp stays normal.
I'm hungry!
