Old 07-13-2015, 08:46 PM   #51
crazycal's Avatar
Just walked in the door. Now I get some sleep!!!
I'm hungry!
You Gotta Let Me Fly
Old 07-13-2015, 09:36 PM   #52
Better eat first!
Old 07-13-2015, 09:40 PM   #53
Forget the food...have a tasty adult beverage and you will rest better.
Old 07-14-2015, 09:06 AM   #54
crazycal's Avatar
Originally Posted by Hvbuzz View Post
Are you home yet CC?
I've been thinking quite a bit about this thread and your journey. I haven't had a problem with the bus overheating till this vacation. This morning, I pulled the inner fenders out, and that made almost a 15 degree drop in water temp. I couldn't believe it helped that much. I think my inner fenders will be staying off for now on. When I get home I will be doing a full size radiator and inner cooler swap this year.
I will need to look at my fenders. The list of mechanical items to be done to the bus in no particular order. Probably cheap and easy will play into the decision.
1. Larger tires. Has 9R22.5, will go to 11R22.5
2. Find at least one or two 6 lug 22.5 rims for spares.
3. Replace split radiator and intercooler with full width units.
4. Incorporate brand new motor grader hydraulic cooler into transmission cooler system. I already own this.
5. Install MT647 transmission that I bought from Choolbuus on my way back from Texas.
6. Change rearend gears if and only if this doesn't bring the rpms down to 2000 at a comfortable cruising speed. FASTER THAN 45 MPH!!!
That's all that I can think of right now. For the inside, a quick setup to get my RV title. This needs to be done as fast as I can get it done. The bus is very solid. The items listed above are only improvements for long distance driving. Nothing wrong with the bus as it sits other than screaming down the freeway while cruising 55 mph.
I'm hungry!
Old 07-14-2015, 09:26 AM   #55
Here again is the URL for a really handy gear/tire size/rpm/speed calculator. The one at the bottom of the page lets you play "what if" with any combination. Like I said...handy...
Engine RPM Calculator
Old 07-14-2015, 09:38 AM   #56
crazycal's Avatar
I can live with those numbers. Thanks.
I'm hungry!
Old 07-14-2015, 02:22 PM   #57
Year: 1994
It was a pleasure meeting you crazycal and working all day getting the transmission out of my bus. I think you will have a really nice setup when you make the changes you listed. Here's another gear calculator that lets you put in more variables.
Gear Ratio Calculator
Choolbus is offline   Reply With Quote
Old 07-14-2015, 06:23 PM   #58
crazycal's Avatar
Thanks again for everything. Sorry I didn't reply to your last text. I had clients in the car then forgot.
I'm hungry!
Old 07-15-2015, 10:46 AM   #59
crazycal's Avatar
I drove a real car last night with the cruise set at 65 mph. It felt like 150 being that low to the ground. It was definitely a strange feeling after driving 1800 miles at 45-50 mph.
I'm hungry!
Old 07-23-2015, 06:01 PM   #60
crazycal's Avatar
Originally Posted by juliol View Post
Ok guys, based on CC experienced, what would be the best way to keep the bus engine cool under same circumstances?
J
Are you talking about the first part of the trip towing the Excursion? If so, I wouldn't tow the EX. Too much weight.
If you are talking about Hvbuzz, I think he might have had a problem with his fan clutch.
I'm hungry!
