Old 08-03-2017, 05:57 PM   #11
Removed my heater for now so it's out of the way while I work on the floor.
jukes13 is offline   Reply With Quote
Old 08-03-2017, 06:03 PM   #12
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Consider replacing that heater with this: - a hydronic baseboard heater.
Old 08-03-2017, 09:20 PM   #13
Do explain more for those of us with no knowledge of those units please.
Oldcarnut is offline   Reply With Quote
Old 08-04-2017, 02:27 AM   #14
Basically the coolant of the engine will run trough and heat up the radiator inside and you will have heat ONLY when running the engine.
You can add a valve before to turn it off on summer, is basically the same kind of heater you pulled off but flat and with no fan.
pepepito is offline   Reply With Quote
Old 08-04-2017, 10:00 AM   #15
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
You go, nip the rust right in the bud. OSPHO that and it'll be looking sharp. Luckily looks like just surface rust and not much deep pitting, that's great.
Skipoffools is offline   Reply With Quote
Old 08-04-2017, 01:25 PM   #16
Wow thanks for the suggestion! Hadn't seen this model before. Will definitely look into it.
Old 08-04-2017, 01:27 PM   #17
I was pretty excited with the condition of the floor. Will definitely prep it and get it treated.
Old 02-02-2018, 12:55 PM   #18
Itís been a hot minute, but the build continues. Itís slow going with work and the bus being 40mins from my home. But Iím happy to have a safe place to store my skoolie while I slowly make progress.
Pretty much done with deconstruction and about to transition into construction. Pretty darn exciting.
Old 02-02-2018, 03:20 PM   #19
Robin97396's Avatar
This is a fun time with a sense of accomplishment for your bus. Now the spending starts.
Robin
Nobody's Business
