With what you want to do, it depends more on how you plan to charge the batteries. We've run a similar "house load" for years on a single 120AH deep-cycle battery. We'd charge it each day by running the generator for a few hours, or hooking up the car.
Small devices have small draw and can run for a long time this way. Even a "big" laptop draw is typically only 75-95W. A microwave off an inverter is going to be 1000-1500W - MANY times more. It's when you start talking microwaves, griddles, toasters, (big) refrigerators, furnace fans, water heaters, etc. that you start needing more sophisticated solutions.
If you Google around you can find dozens of calculators and spreadsheets for figuring out how to size a system. Here's just one example:
calculating your solar power needs
You need to do some math on what you want to do before asking for general advice. Otherwise it's just guesswork.
