Old 06-30-2017, 03:18 AM   #121
Originally Posted by Tango View Post
Did I accidentally reset the language here somehow???
You guys are talkin WAAAY over my head.
They lost me somewhere along the way as well.
And while I have just a bare inkling about what they are talking about I like the fact that someone on here really knows something about the electronics on the newer buses.
As the years go by there will be fewer and fewer all mechanical buses left on the road. All of us who know how to work on them will be very appreciative to those you will be able to hold our hands as we wade through the murky depths of VSS, TCM, ECM, 555, and who knows what else!
Old 06-30-2017, 08:07 AM   #122
555 is actually old.. it was of course created as a device for use in big projects.. but it ended up becoming the Standard and sometimes the initiation of the Geek-hobby-electronics .. to build a little circuit that made an LED flash off and on as a kid was a cool thing..
electronics - there is a real trend happening with vehicle electronics which is likely goingto render the independent shop useless in the next coming years..
allison has already started with it in that they have made it nearly impossible for anyone but an allison dealer to reprogram a TCM (Transmission control Module).. we are starting to see more and more of it in consumer vehicles in that aftermarket devices are rendered more and more useless.. obviously its done in the name of keeping people from modding their vehicles.. (so they say). but reality is at some point all that will happen is the manufacturers will fail to license the software to anyone but a dealer.. without the software its nearly impossible to troubleshoot complex issues..
lets take even my build here... how much have the various electronic and software testing tools played a part? in a project that all in all should be mainly a mechanical transmission swap, and here i am knee deep into the electronics..
granted.. there ARE mechanical solutions to my issues as well.. but they would involve custom fabricated tone wheel driveshaft collars and the like...
should the electronic route fail.. then we have to revert to crazy one-off systems..
alas where my mind does go.. to take the TCM fed signal and turn it mechanical and then make it electronic again.. really?? yeah it can be done...
SPEEDBOX™ GPS/VSS to Mechanical Drive Speed Converter
makes the TCM signal and turns into a mechanical spinning speedo cable...
yep and then you can turn the cable into electronic... ahh yes wierd huh?
Mechanical Speedometer Cable Adaptors
alas likely ive solved this one electronically... but i COULD go this route if i had to..
Old 06-30-2017, 08:18 AM   #123
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Yup the 555 dates back to when "Radio Shack" ment more than a store. Bread boards were not in a bakery and tie wire was not just for fencing lol😂
Tootalltechie is offline   Reply With Quote
Old 06-30-2017, 08:30 AM   #124
totally.. the days of going to radio shack and browsing the 1000s of little drawers of electronic bits to build stuff! lots of little 'ARCHER' bubble packs in my history!
fortunately in columbus ohio 'Micro-Center' and 'Electronic Supply corp' have really taken to the hobby electronics crowd .. and with the popularity of raspberry PI and Arduino type devices.. (arguably started the trend was Basic stamp).. have brought back the component level building and breadboarding once again..
Old 06-30-2017, 08:48 AM   #125
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
time to grab the transmission scan tool and connect it.. because if I go over 140 degrees F trans temp im screwed.. it enables the learning mode.. and that we dont want to happen till we want to teach it.. plus i needed to monitor the Output shaft speed on the trans.. the other piece of making this work is making sure that while my dash can see the signal so can the transmission!.
How is it you have all these scan tools?
by george i think i got it!!! I still set a code occasionally when I restart the truck.. the values of these resistors saeem awfully high so i may adjust them a bit. with Pots and see if i can come up with something thats not on the edge literally... nevertheless I came up with the schematic below that so far works on all accounts.
YOu're a smart kid so I suspect you've already tried but I gotta ask... it's not something you can take the lid off of and see/measure the resistors? Proprietary so not likely to find the values online I reckon.
I MAY have to put a 555 timer circuit in for when I first start the bus until the ECM and TCM boot fully before letting the VSS signal apply...
It's been a long while since ...
One thing..... I had you pegged as being quite a bit younger than I am until you made that comment. I don't think anyone under 45 know what a 555 is.....
Damn it, I made the cut.
I'd go a little further tho. Maybe 40 or even late 30s depending on how geeky and old-school the person is. FYI, Bose (the speaker people) were using thru-hole technology into the 2000s. Don't know if they still are or not.
And I thought you were mechanical and here you are going all electronic on us.
and of course there are alot newer things to use than a 555.. but really its super simple and easy to use.. for what I need it for its perfect.. or i could just buy something like this
I didn't look at your link but is anything new going to be as robust? A 555 chip doesn't give two shits about static, vibration, weather, etc.
i can feel it now!! i can taste that bus ride now!! Hot summer night road trips in the skoolie!! my favorite times to travel!.
I like ya but you are still a sick puppy. Just thought you should know.
Originally Posted by Tootalltechie View Post
The 555 is the cats meow. I use to use them for everything.
Welcome to the geezer club. Put your teeth over there and have a jello.
A 555 timer is an IC (Integrated Circuit) from back in the '80s and earlier. It is used as a "delay". Think old school stuff. You pick up the phone, wait for a dial tone, then you call the number. A modem and computer are faster than your fingers even if you know Aunt Sally's number. It will start dialing before the connection is made. Enter the 555 timer. You need a 5 second delay, 10 second, etc.? You get one of these guys and your modem waits for however long you are looking for then dials.
Chris needs a delay when the bus is turned on. Don't check the signal as soon as I put the key in. Wait 5 seconds until everything is connected, already spinning and at speed, etc. I wouldn't be surprised at all if these old buses have 555s in the ECM TCM.
Thru hole --- If you pop open your phone, TV, etc. you will NOT find anything that is thru hole technology. The pins went thru the circuit boards and were soldered to it. Everythign these days is surface mount. Everything is soldered to the surface of the board. Big deal right? Well it kinda is. 1) you don't have to drill holes any more so it's cheaper. 2) You can run traces (wires) thru the board without dodging holes so you can make more connections. Now it's cheaper and smaller. And that's just the circuit card without taking into consideration the parts themselves getting MUCH smaller.
555 and thru hole
surface mount .... the black ones are resistors
I take my hat off to Chris. I know exactly what he's talking about, can read his schematic, etc. But he probably has the schematic of the 555 memorized. He stayed in the electronics industry. I'm on the fringe of it. Shouldof, wouldof, couldof stayed in it myself.
This is VERY old technology. The new buses will be scary. I dunno if they are caught up with cars or not.
Fly by wire ... there's no physical connection between the gas pedal and the engine. Carbs died years ago. Distributor caps are "retro art". The computer dies and the car dies. I imagine that the brandie new buses '17/'18 and going forward already are there. With the EPA over reaching, fuel expectations, and so on it will happen.
Old 06-30-2017, 09:05 AM   #126
Brewerbob's Avatar
Good to know. All of this stuff can be bought online but it's way more fun going thru the bins. And I have a problem with paying 47 cents for your 555 and $5 for shipping.
Old 06-30-2017, 09:49 AM   #127
believce it or not the redbyrd (year 2000) is fly-by-wire.. theres no physical linkage on the accelerator.. in fact all the HEUI emgines were... fly-by-wire is much easier to do on a diesel that has electronic injectors than a gas engine where you have to control air inlet and injectors..
MY HATS OFF to brewerbob! who i thought was onlty mechanical and dang!! this boy knows electronics!. I love it!!!
as far as scan tools... well im kind of a tool-geek... moire than hand tools.. im into scan tools.
Old 06-30-2017, 11:21 AM   #128
You guys are reinforcing my theory that in just a few years there will be no more Skoolie builders. Once all the mechanicals are bought up, then what? The damned new buses are becoming so complex that the average Joe/Jane will not be able to manage all the BS technology packed into them. But then...to my mind...that's been the plan for years now.
Old 06-30-2017, 11:58 AM   #129
Brewerbob's Avatar
I just don't like "smart" cars. Mr. ECU ...The rear window is down but there's no weight in the seat and the seat belt is buckled. I don't think you are going to the grocery store after all.
MY HATS OFF to brewerbob! who i thought was onty mechanical and dang!! this boy knows electronics!. I love it!!!
7 1/2 HS credits in electronics. Normal geekitude is 4 credits. Senior year I went to the vocational school for 3 1/2 hrs. It counted towards HS credit. Was also T.A. for one of the jr classes my senior yr. Taught the newbies how to light off the electrolytic caps with a power strip, "weld" with the power supplies and the mechanical pencil lead.
Navy telecommunications school as well. Had some radar schooling too. But all of that and the HS was literally 30 yrs ago. 30 yrs ago this year. Class of '87 so you're the same or +/- a yr depending on bday.
After the Navy I went back and finished the vo-tech electronics course. It went as far as basic microprocessors. Was working in electronics at the time. Interviewed for two jobs; QA and Test Tech. Test tech was on the production floor. Here's a bucket full of boards that failed test. Fix them. Are you done? Not yet; how about now? NOW? The QA job was in the "back closet". Some guy that had been there 2 yrs literally thought it was a broom closet. I'll take the job that doesn't have someone breathing down my neck.
Oh took 1 semester of Apple Basic in HS too. It was a yr long class and the mid term was write a program for the chance of rolling a 7 using two 6 sided dice. Um, how about I just tell you? The class was boring as hell so I dropped it. Had the teacher been good, (s)he would have given me something more interesting to do. I honestly can't even remember the teacher tho.
as far as scan tools... well I'm kind of a tool-geek... moire than hand tools.. I'm into scan tools.
Anything that needs a scan tool is too complex for me these days. Had I stuck with the programming or the test tech career path, I would be your twin.
As for you actually having them, aren't they as expensive as hell? The kid next to me at work has the tool that Saab used but he was a long time Saab fan boi/geek.
If I have to pick a tool, I'd much rather have a hand tool as in wood, metal, etc working!!
Old 06-30-2017, 03:44 PM   #130
Engine: TE 444
Rated Cap: 12
I am waiting for the redbryd plug and play transmission module to put anew allison 1000 in mine, I never did electronics
