Old 06-20-2017, 09:21 AM   #81
Originally Posted by Brewerbob View Post
Not to pick on you but how did you get this old and do hot rods (mechanical stuffs) and not already know this? Glad to be of service tho.
The more weight and tension on the gears the better. Harder to overcome to get the gear "free" but also less likely to have a "run away" as well. Your 450 lb tranny would have been fine.
I never needed ratchet straps for hotrods.. I always had ramps to drive up on to pull transmissions ..and being smaller, they always wheeled right out from under the car on the jack so no need to support it.. I would use an engine hoist to support the rear of the motor while the trans was out.
the engine hoist was also used to bench a transmission where i could make repairs if needed.. I only ever rebuild the simple stuff when it came to trannies.. (TH-350s), once i discovered OD stuff I had a shop build the trans.. id just yank it and haul it off to them..
pulling engines i used the engine hoist and would mount the engine on a builder stand to build..
no ratchet straps needed..
when I used them in the bed of the truck to tie stuff down it was always full release.. no need to ratchet it "out"...tie down and release..
never used them out 4 wheeling either.. one of my jeeps had a winch when I thought I wanted to be more serious at 4 wheeling.. but decided that my tendency of wanting my Jeep to Look brand new inside and out didnt go along with 4 wheeling so I never had another winch.
BTW im not old yet.. started building stuff when I was young.. always done it since.. 48 years young, i figure I got alot of years and alot more projects to build left in me..
these busses wont be around forever.. I'll have fun with them for awhile and then build something else..
Old 06-20-2017, 09:55 AM   #82
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
Ah I see. You didn't have them tight then. They will get to a point where you have to release slowly. I'm of german descent; goodentight.
That's old. Takes one to know one; also 48. I dread the point when I CAN'T do stuff myself. I'm already at the point where it hurts to do it myself. I don't know if there will be any projects after the bus. It very well may be the death of me.
Old 06-20-2017, 10:28 AM   #83
Chassis: International 1753
Engine: 6.9 International
I mightr be hitting you up for info on the 3rd member.. I noticed my pinion seal is seeping a bit... the bearing still feels nice N tight.. havent figured out if I can take it apart, change the seal and put it back together without complete disassembly or not...
I know on my old hotrod stuff it had a crush sleeve.. once you loosened up the pinion nut you were supposed to put a new sleeve in which required removing the carrier and setting it all up again..
are the busses similar? or is pre-load set differently and the seal just pressed in behind the yoke?
Depends on the rear end that you have. However, most of the time you can use a chisel to mark the location of the nut relative to the shaft and replace the seal without replacing the crush sleeve (even on ones where they say to replace the sleeve).
Remove the driveshaft. Mark the nut and shaft(I'll also mark the yoke so as to keep everything the same). Remove the nut and yoke. Replace the seal. Reinstall the yoke. Tighten the nut so that the marks all line up. Then reinstall the driveshaft.
Booyah45828 is online now   Reply With Quote
Old 06-20-2017, 12:41 PM   #84
Engine: TE 444
Rated Cap: 12
You can change the pinion seal on this type of third member without messing with the gear setup, the pinion yoke is on a splined shaft and taking the nut off in the center allows you to pull it off and change the seal, if the yoke is grooved, new ones are under 100 and just bolting back on. Think you also need a new nut because it is a lock nut
Old 06-20-2017, 01:25 PM   #85
is it a torqued nut so there is no preload necessary on the bearing? I can just hit it with my air-gun to remove and then torque it back to 80 after seal replace like the old Chrysler / MOPAR stuff?
Old 06-20-2017, 02:55 PM   #86
Engine: TE 444
Rated Cap: 12
The preload is provided by other nuts on the input shaft, so the one that removes the yoke just holds the yoke on
Old 06-20-2017, 06:42 PM   #87
this is awesome! great info!!! thanks!
Old 06-24-2017, 09:07 AM   #88
just a quick update... work's been crazy busy.. and yesterday was the tropical depression rain from H*LL.. while my bus is under roof itsn ot compoletely indoors, so laying underneath it was completely out..
however day before last i did manage to get a couple important things done.
got the driveshaft back from the shop, installed it, and it fits PERFECTLY.. thats one measurement i mustve done 30 times... fits right into the plate where it did before.. the magic number ot shorten it was 1 1/4".
then I was able to get my shifter bracket made and test fit.. without even adjusting the shifter in-cab I was able to go through all the gears RND321. and have no tension on the cable when the shifter was locked into each gear. this means i got the geometry right. there is enough clearance if i want to use park, but I either have to get a new Cab shifter, or take it apart and see if I can grind off the stop on the gate. I'll do that at a later date.. I may look for a shifter that has a P on it and the proper 4-2-1 instead of 3-2-1 labelling. not that i'll ever use the hard shifter to go downward as Ill have the electronic shifter..
things werent tightened up in the pic.
by "Geometry" what is meant is that the shift Leveer "on the left of the pic" is pulled by the cable to go towards 'Park', and the cable 'Pushes' out to go toward '1'. what you do is go in the cab and shift the shifter to the top.. 'R'.. then crawl under.. that cable should not be under any tension.. the little 'hook' should pull in and out of the shift lever bracket easily.. go to the next gear, test and so on.. the cable should never be under any tension when locked into a gear up top.. if it is under tension all the time you can rotate the 'hook' on the cable and then reinsert it into the lever..
if ytou find that only in some gears your cable is under tension.. ie tension gets stronger as you go through, then your "geometry" is off.. or the angle of the cable as it is in relation to the shift lever.. you would then re-position the cable anchor bracket (on right) higher or lower until you achieve an angle that causes no tension on the cable in any gear..
this is extras important because with incorrewct settings you can destroy your transmission in a short amount of time.. with enough tension on the cable.. the shift lever may not fully engage.. which results in an internal valve being partially open or closed.. low fluid pressures and burnt up clutches can result..
so then I took the shift bracket home, ground a little off the corner so it clears the neutral safety switch wire better, etched, primed, and painted it.. ready for final installation..
Old 06-24-2017, 09:23 AM   #89
Hell yeah, that's awesome.
Roll Your Own Build Thread
Old 06-24-2017, 09:28 AM   #90
BayStateOfMind's Avatar
Coachwork: Blue Bird Micro Bird
Chassis: Ford E-450
Engine: 7.3 PowerStroke
Rated Cap: 10P+2WC (5 Window)
That swap's looking great so far! Can't wait to see the first test drive!
- Sean
Sean 🤓
BayStateOfMind is offline   Reply With Quote
