04-05-2014, 10:23 PM
#341
Engine: 190hp 5.9 Cummins
Re: The Roach Motel
04-05-2014, 11:18 PM
#342
Re: The Roach Motel
Hey Roach. You said"(I) added 200 amp fuses to both ends of the cable between the starting and house banks". Do you mean that you added one each to both the start and house system or one at each end of the start and house systems? Total two or total four? Jack
04-06-2014, 09:48 PM
#343
Rated Cap: 19
Re: The Roach Motel
I ran a 2/0 cable between the starting and house banks so I can charge the house bank with the alternator or jump the starting bank if needed. That cable runs through a tight spot and even though I've added quite a bit of protection to the cable it could chafe in time and I'd imagine having both banks shorting through that cable might make for a very interesting afternoon. With that in mind I added a 200A fuse on each end of that connecting cable (two fuses).
04-06-2014, 10:13 PM
#344
Re: The Roach Motel
You do have some kind of disconnect between the two batteries, right? I see a disconnect switch in your cost breakdown, but don't remember if you showed earlier where it was wired. I don't remember if you showed an off/on or an off/1/2/both switch.
Without a switch, relay or isolator, a permanent connection between the two banks will run down your starting battery along with your coach battery when parked.
04-06-2014, 11:06 PM
#345
Rated Cap: 19
Re: The Roach Motel
The disconnect switch (a simple on/off switch) is between the two banks and is normally off - I nearly always charge the house batteries with the three stage converter/charger rather than with the alternator.
04-29-2014, 10:09 PM
#346
Rated Cap: 19
Re: The Roach Motel
I really like Bansil's turtle motif on La Tortuga and over the winter thought about doing something like it on our bus. We briefly thought about getting some little roach stickers but while they are available online it seemed like we were taking the "roach" thing a step too far and were going from kitschy to creepy.
Since we have two cats we decided to go with cat prints instead.
The new starting batteries have been a good improvement. When cold starting with the old batteries I'd see voltage briefly dropping down to 11 volts while the glow plugs were active and peak charging volts just above 15 volts. The new set stays above 12 volts when starting and peak charging volts top out at 14.8 volts. Life is good.
04-29-2014, 10:47 PM
#347
Re: The Roach Motel
Loving the kitty prints.
My girl friend and I sleep with her 11 year old kitty. Nothing but love for kitty's.
06-15-2014, 06:59 PM
#348
Rated Cap: 19
Re: The Roach Motel
We had an "all brake line" couple of weeks with our three vehicles. First, I get a call from the wife telling me the brake pedal is real mushy on her Buick. I drove over and sure enough, one of the front brake lines was rusted through. We had it towed and $1300 later she's got new brake lines. A week later we took Roachie out to top off the diesel tank and as we pulled out of the gas station the blasted brake pedal goes from high and firm to soft and mushy. A quick look confirmed that one of the rear brake lines was rusted through. That one cost us $650 for three new lines and two hoses. Then, to top it all off, a few days later I was replacing the rear shocks on my van and cracked ANOTHER BLASTED BRAKE LINE! That one cost $400 for two rear brake lines and two wheel cylinders.
I've been driving for 40 years now and have never had a brake line leak (and I tend to drive my cars until the wheels fall off). To have three leaks in three vehicles in three weeks is just too freaky. On the other hand, I figure I've just run through my lifetime quota of brake failures.
06-15-2014, 07:30 PM
#349
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: The Roach Motel
Ouch! Are buying lines from the dealer-and having them install them? Thats crazy expensive. A 5 ft section of 3/16" line from the parts store is under $10 -a cheapo flairing tool maybe $35 + cutter $20. Just like all the new stuff you learn from building an interior, its just another skill to aquire.
If MI. is like Ct., they now squirt some form of brine on the roads before a snowstorm-rather than salt after it starts. And the amount of under vehicle rot has drastically increased.
06-15-2014, 08:32 PM
#350
Re: The Roach Motel
Bad stuff happens in three's.
06-15-2014, 09:53 PM
#351
Rated Cap: 19
Re: The Roach Motel
I'd have been happy to tackle the repairs but time was against me. I did look up the finer points of building brake lines and it didn't look like any big deal, just had too many irons in the fire. Shelling out all that cash was NOT my favorite thing.
Interestingly enough, I used three different shops for the repairs and all three were charging about $200 per installed line. The cost of auto repairs is pretty insane.
06-16-2014, 03:20 PM
#352
Re: The Roach Motel
Just a note on brake line flairs. The cheapo flaring tools can't do the DOT approved double flare where the end of the line is first bent in followed by being flared out--you'll see what I mean if you look at the end of a factory flared line. The reason for the double flare is that the outer edges of the double flare doesn't split at the pipe seam and leak.
06-16-2014, 03:59 PM
#353
Rated Cap: 19
Re: The Roach Motel
Yeah, I took the "Internet Brake Line Flaring class" when the second line let go. Couldn't put the knowledge to good use but I'll know how next time. Of course, next time I have this problem I'll probably be 90 and won't be able to crawl around under the beast like I can now.
It would be interesting to make a list of the new skills I've learned while doing our conversion. If I'm really bored some winter's day I may just give it a go.
06-16-2014, 09:09 PM
#354
Chassis: B3800 Short bus
Re: The Roach Motel
My father-in-law (sort of?) let me use his kit from Harbour Freight a couple months ago. It could double flare and it cost him all of $25... worked fine. It was a two part process. I'm not sure if the better ones do it in one step, but for a few brake lines it really wasn't a big deal.
Moral of the story: read the package. Make sure it's legit.
06-16-2014, 11:17 PM
#355
Re: The Roach Motel
Thanks Jazty, thats a really good tip. I'll have to see if my local HF stocks them as it would be handy to have. As far as I know the double flare is always a two step process which makes the HF tool look all that much more interesting.
06-17-2014, 10:20 AM
#356
Re: The Roach Motel
I guess the "good news" is that in spite of the expense...it worked out a whole lot cheaper than if any of the three had involved a crash. And given that the average bus can take out a medium sized motel...probably a LOT cheaper.
Monty Python --- "Always look on the bright side of life".
06-17-2014, 05:15 PM
#357
Rated Cap: 19
Re: The Roach Motel
Roger that! If you think you've got it tough, just look around.
The Buick lost it's front brakes but I didn't try to drive it. The bus and my van both lost the rear brakes and I drove both of them home then to the shop. The front brakes alone did a pretty fair job of getting both vehicles stopped even though there was a LOT of pedal travel. I wouldn't want to drive in heavy traffic with half my brakes out, but it wasn't as traumatic as I imagined i would be.
Whoever thought up the split braking system did us all a huge favor.
The video I saw showed the double flare as a two-step process. The first step "bulged" the end of the tube and the second step folded the bulge back on itself to make the flare.
06-17-2014, 08:03 PM
#358
Coachwork: Champion
Chassis: Ford e-450
Re: The Roach Motel
Yea--Its actually pretty easy. Every mechanic I know has the exact same kit-made by either KD or Lisle. It comes with a a clamp "vice" that holds the line- and piece that makes the flair-and a screw clamp with a point on it. You leave a bit of line out clamp vice (using that piece to set up the right height) the piece now gets put over the line-and you tighten it down till it bottoms out--thats flair #1. Now remove that piece + put the pointy end in the end of the line + tighten down-thats flair#2.
Edit: Oh lookie http://www.ebay.com/itm/10-Pc-Brake-Air ... ls&vxp=mtr
Other tool you need-a tubing cutter-i recommend the "Imp" style -its small + can get in tight places. http://www.ebay.com/itm/Mini-Tubing-Cut ... 35ce8b779e
And this is the get you out of trouble fix. Cut the line at the leak-clean up both sides with some sandpaper + install thhttp://www.ebay.com/itm/Allstar-Brake ... &vxp=mtris ferruled fitting.
06-26-2014, 10:05 PM
#359
Rated Cap: 19
Re: The Roach Motel
We had a very weird adventure last weekend.
So there we were, heading home from the family camp on Sunday at about 4:30pm when I hear a "clunk" at the back of the bus and look back in time to see a small "something" bouncing down the expressway behind us. It could have been from another vehicle and the engine was running fine so we kept driving but a couple of miles down the road the windshield fogged up and I could smell antifreeze so we pulled into the breakdown lane for a quick look. The power steering and power brakes had lost their power so I knew I had a problem with the serpentine belt. Popping the hood revealed that the belt was fine but one of the idler pulleys on the tensioner had called it a day and bailed out. Fortunately we were near an exit with a gas station so we got off the road to decide what to do next.
I knew I could fix the thing with the tools I had with us but how to get that bloody part late on a Sunday afternoon? Just when we were about to call for a tow THIS GUY pulls up in a nasty, ratty old pickup truck, rolls down the window and says "I'm a mechanic. Can I give you a hand?" I said that he most certainly could so he had a look and said he could pick up the part and install it for $100 plus the part. It all sounded too good to be true so I went inside ostensibly to get us each a Mountain Dew and while in there slipped my carry pistol into my pocket. The guy called Autozone to reserve the part and asked if I could front him some cash to pay for it. I gave him $80 bucks for a $62 dollar part and off he went to pick it up. I'm generally a trusting person but the thought crossed my mind that he could just take the cash and head for the bar.
While he was gone I pulled off the engine cowling and about the time I had it off here he comes, part in hand. We proceeded to pop the thing in and check for collateral damage (apart from some nicked fan blades there was none). I gave the guy the hundred he'd asked for plus a nice tip and we talked about the bus and our conversion for a bit. Turns out that the guy would cruise up and down that stretch of the expressway looking for broken down vehicles. He would change tires, arrange for towing or fix stuff himself for (tax free) cash. Not a bad gig.
He was quite the jokester and yakked on and on but bottom line, from the time we broke down to the time we were repaired and on our way was about an hour.
Neither of us could believe our luck. Had we gotten towed we'd have probably spent the night in some repair shop's parking lot and paid twice as much for the fix. Instead, we got home just a bit later than we normally would have. The whole thing was surreal.
06-26-2014, 11:52 PM
#360
Re: The Roach Motel
Sometimes...life is grand --- When it is, I just say "thank you".
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Rolling Motel Room
wtd |
Skoolie Conversion Projects |
35 |
12-09-2011 02:05 PM |
