Old 08-04-2016, 09:44 PM   #411
Roach. You have to do any mods on your door opening to fit the new door.
fnelson71 is offline   Reply With Quote
Old 11-13-2017, 01:36 AM   #412
Joshshortbus's Avatar
Roach711
Where did you get your blue gray tank? That looks like it would be perfect for my black tank. I have a 99 e450 shuttle just like yours. I think your post is my new favorite.
Joshshortbus is offline   Reply With Quote
Old 11-13-2017, 10:28 AM   #413
roach711's Avatar
Rated Cap: 19
I got mine on ebay for $35 but you can sometimes find them on craigs list.
The Roach Motel
Old 04-29-2018, 09:47 PM   #414
roach711's Avatar
Rated Cap: 19
This spring I decided to throw some new parts at Roachie. The starter was my first swap. CadillacKid posted a video of his DT444 starting and it spun up WAY faster in cold weather than m 7.3L did on a warm summer day. Mine always acted like the batteries were low when cold starting. I picked up a new OEM starter and MAN does it start good now! What ticks me off is that I had the Ford stealership check the slow starting issue when I had Roachie in for another fix and all they did was swap out the batteries. Boneheads.
Today's project was to do a cooling system refresh including the radiator, all hoses, the water pump, the fan and the fan clutch. These E-vans are a pain to work on but I got it done in one day. Tomorrow I'll give it a good run and if there are no leaks (fingers crossed) I'll replace the coolant and SCA too.
The Roach Motel
Old 05-09-2018, 05:57 PM   #415
Hey Roach, how was installing the door? we are gonna go with the Andersen 4000 as well and wanna see if there are any tips you can bless us with?
Smiley
smiley is offline   Reply With Quote
Old 05-09-2018, 06:06 PM   #416
oricha1984's Avatar
Engine: gasser probably
ty
just finished reading this thread.
very good info,
thanks for sharing
oricha1984 is offline   Reply With Quote
Old 05-09-2018, 06:53 PM   #417
roach711's Avatar
Rated Cap: 19
Smiley
The door installed fairly easily. I had just enough door opening width to fit it in and the original steel door frame made installing the Anderson door frame very straight forward. My door opening was about 4 inches too tall for the Anderson door so for better head room I built up the bottom step instead of trimming out the top. After a few years I did some tweaks to keep the hinges from wearing out and to limit the rattling on rough roads. Look at post #407 above for those.
The Roach Motel
Old 05-10-2018, 06:11 PM   #418
what were the measurements of your door opening before installing? thanks for so much detail in your posts, they help so much.
Old 05-10-2018, 07:26 PM   #419
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
That is PRECISELY the door I've been looking for! Who supplied it?
Old 05-10-2018, 08:12 PM   #420
roach711's Avatar
Rated Cap: 19
After removing the original bus bi-fold doors I had a 35 3/4" rough opening. The Anderson door frame wanted 35 1/2" of that. Height wise, I had about 3 inches of slack. I re-drilled the Anderson frame so I could use the bolt holes in the original door frame.
Capt Squid - It's an Anderson 4000 series storm door that I got at Home Depot. Current price is $240 for the 36" door and $42 for the door handle.
The Roach Motel
Rolling Motel Room wtd Skoolie Conversion Projects 35 12-09-2011 03:05 PM
