Old 10-21-2010, 07:07 PM   #1
Engine: 5.9 Cummings
Rated Cap: 24
The uprising of the "Green Machine"
My name is Kurt from Hartford WI and I bought my first bus a couple of months ago. It's a 1999 24 passenger flat nose Blue Bird with 24 valve 5.9 Cummins diesel with Allison tranny. So far I removed the seats, stop sign and other red school lights and painted it. In the spring I will finish the black trim portions of the buss. My fuel tank sprung a pin hole leak shortly after I had it.I'm in the process of getting that fixed. I have a couple of sheets of plywood pulled up from the floor. I plan on fixing the rust spots, probably painting the floor with a coat of Rustoleum and then maybe a coat of undercoating then new 3/4" plywood.I will have questions about the correct ways to do certain things on the bus. ( heat, power, etc.) It's great to look at the gallery to get ideas.
http://www.skoolie.net/gallery2/v/Skooli ... 2.jpg.html
funbus63 is offline   Reply With Quote
Old 10-21-2010, 08:55 PM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: The uprising of the "Shagg'n Wagon"
Reminds me of the lime green gremlin that was on tv commercials a while back. Good start to it, keep the pics and progress coming....
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 10-22-2010, 12:37 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Wow. That is an eye-catching color you chose. The lack of wheel well humps will give you a lot of flexibility in your interior design. I think those wheels must be smaller than typical bus wheels, right? Do you have a high roof on that bus? Like maybe 6'6"? Welcome to the skoolie site!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-22-2010, 01:52 PM   #4
Rated Cap: 24
Re: The uprising of the "Green Machine"
I'm not sure on the wheel size. As far as the inside height goes,I'm 6' and I have room above. I never measured it. I guess now I will have to..... I can't wait to get the flood ripped up, holes patched and the new 3/4" plywood down. Then comes the fun of deciding what and where to put it.
Old 10-22-2010, 01:56 PM   #5
Rated Cap: 24
Old 10-22-2010, 05:10 PM   #6
lornaschinske's Avatar
Rated Cap: 89
Nickelodeon fan? Even my daughter thinks it looks like "Slime Green"
Fulltime since 2006
Old 10-22-2010, 07:20 PM   #7
Rated Cap: 24
It must some disease I have. Years ago I had a ultra light airplane and I painted that the same color.I guess everyone has their "thing".
Old 10-23-2010, 04:17 PM   #8
Rated Cap: 24
Today was a very productive day. All the old plywood is out of the bus. Time to patch holes and start putting it back together.
Old 10-23-2010, 07:47 PM   #9
Engine: DTA360
Rated Cap: 16
WOW!!!
That thing is more green than mine...
dirtygoat is offline   Reply With Quote
Old 02-18-2011, 11:14 AM   #10
Rated Cap: 24
Finally got back to doing some work on the bus. I had all new brake hoses made and am replacing the entire brake line system. I couldn't find a way to get to the fittings on the master cylinder so I made a access hole which will be the new location for the brake reservoir.
replaced the entire brake line system including hoses from the master cylinder back
My 1987 IH/Carpenter "Simple Green" charles_m Skoolie Conversion Projects 9 09-15-2013 07:48 PM
The Green Machine Six Four Short-Bus Conversion Projects 3 03-15-2011 11:47 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
Questions about "green" insulation for bus Redbear Conversion General Discussions 11 03-07-2010 06:20 PM
