Old 12-06-2018, 04:44 PM   #1
Coachwork: sturdivan
Chassis: E-350
Engine: 7.3l IDI
Rated Cap: 10,000lbs
Question thinking about tires
My tires have date code between 8-10 years old, the 4 I can see easily. The tread is almost brand new some tires still have the little rubber nubbing from the vent holes. I guess the school just put new tires on before they retired the bus 10 yrs ago.
I've had bad luck with old tires and trying to cross the desert, I tried a few years ago and if it wasn't for a good friend in Fresno, I would still be there.
I've looked at firestone tires, they offered two kinds, their in house brand Primewell; and their name brand firestone. The prices differed by 100%; one was twice the other.approx 85 vs 160 each.
The tires on there right now are 225-75R16 load range E.
can I go with bigger tires? for better gas mileage.
also they quoted rubber valves.
I think I need to keep the metal valve stems I have so i can get a air chuck on the inside ones. I've always had metal valve stems on all my other pickups and never had a problem.
what brands or types of tires are favored.
I'm looking for advice, thoughts and recommendation based on actual experience.
Al
telegram: https://t.me/mr_alpine
alpinekid is offline   Reply With Quote
Old 12-06-2018, 05:56 PM   #2
Engine: 345 international V-8
Bigger tires may rub each other. I run 235-75r16 on my dual wheel pickup and the tires are just touching when fully loaded. You need to look between them and see if the extra width will be a problem.
I like BF Goodrich, but most any major brand should be fine.
Old 12-06-2018, 06:14 PM   #3
Chassis: E-350
Engine: 7.3l IDI
anything special in particular about goodrich?
Al
Old 12-06-2018, 07:44 PM   #4
Just been good tires for me. Handle well, and never had a failure. I have had a few Goodyears, and one set was so squirmy I took them back. My car came with Goodyears and always thought it had rather poor traction. Changed to BF Goodrich and had a noticeable improvement in traction. So it is just what has worked for me.
I have also had a few Firestones, and been good with them.
Old 12-07-2018, 12:16 AM   #5
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
I have Toyos on my E450. A vast improvement over the Ironmans that were there. They are good handling and quiet.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
load range e, tires, valve stems
