Old 04-11-2019, 05:24 PM   #1
Thoughts on buying bus needing work.
Hello all I am new here but I have thought about doing a Skoolie conversion for a while and a bus has been posted for sale that fits my ideal size (24 feet) and fuel type (diesel).
It has a few costly issues. Currently only able to travel 15 mph due to mechanic saying turbo fins are damaged and more than half of the injectors are “bad”.
It’s a 1999 international T444E,
Allison transmission. Under 140,000 miles
Planning on paying less than $2000.
I am mechanically inclined so I think it’s something I can take on.
Any feedback would be appreciated. I am concerned with possible underlying issues, is it normal to have this expensive maintenance with the amount of miles?
Cost of parts is $2,000 without labor costs.
MellowYellow is offline   Reply With Quote
Old 04-11-2019, 05:29 PM   #2
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I'd pass it up
Old 04-11-2019, 05:37 PM   #3
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
There are better buses that aren't broken out there for that price. I'd keep looking.
Ted
Old 04-11-2019, 05:37 PM   #4
brokedown's Avatar
Typically injectors on the T444E last about 250k but that's taking a few things for granted. It's not a hard job but as you note it is expensive. I would expect to find a bus in that same price range that doesn't currently need 2k worth of injectors.
Old 04-11-2019, 05:44 PM   #5
Chassis: IH
I'd not pay more than 500. You're looking at a replacement turbo which will be more than a couple hundred bucks (some turbos go for over a thousand); I'd expect this one in the 4-500 range or more. And injectors, there's 8 of them which are north of $200, *EACH*. I'd figure a couple thousand for that job, as you'll want to replace the valve cover gaskets/glow plug wiring harness (they're kind of made together), and that's just for parts alone.
Old 04-11-2019, 05:47 PM   #6
The mileage is likely not correct, as 90% of buses this old have had the dashes replaced and they don't correct the mileage when they do. The money you are looking to repair would easily buy you a bus that doesn't need repairs right up front. Walk away from that one.
Old 04-11-2019, 05:52 PM   #7
Johnny Mullet's Avatar
Engine: T444E 7.3L
Pretty premature for the injectors to be bad at that mileage. If you can get the bus for scrap value, then go for it. Otherwise keep looking.
Old 04-11-2019, 05:58 PM   #8
Wow thanks to everybody that responded. Seems like a definite no. The search continues.
Old 04-11-2019, 09:40 PM   #9
Engine: 6-71TA
Rated Cap: 90
Unless you can pick it up for almost free, I would keep searching.
GWRider is offline   Reply With Quote
Old 04-12-2019, 06:01 AM   #10
You can buy one that runs and drives for that.
Offer em scrap price.
