Old 04-03-2010, 10:19 PM   #1
Atridox's Avatar
Engine: Gasoline
Tread for steps
Any one know where I can buy the classic rubber tread flooring for the steps into the bus? The original in my shortie was blaock with about 2 inches of white right at the edge of the steps? I am a bit of a purist and would love to get something much like the original.
Thanks.
Atridox is offline   Reply With Quote
Old 04-03-2010, 10:53 PM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Tread for steps
Check at a Bluebird dealer, they can probably still get replacement step mats for your bus. I am replacing mine with rubber checkerplate mat, but I don't think my original ones are in good enough shape to be worth saving. They have some cracks at the edges and who knows what underneath...
Old 04-04-2010, 02:32 PM   #3
Atridox's Avatar
Engine: Gasoline
Re: Tread for steps
Thanks
Old 04-04-2010, 06:43 PM   #4
busdriver_phil's Avatar
Coachwork: AmTran RE
Re: Tread for steps
http://commerce1.cera.net/tacbusparts/s ... cat_id=493
Might be a little cheaper than a dealer. I believe the first two on that page are what you need, but I'd suggest calling them before ordering to make sure.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 04-04-2010, 09:41 PM   #5
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Re: Tread for steps
Holy crap, those are expensive! I am going to try to save mine when I remove them in case anyone needs them. No guarantees though, I will take a closer look tomorrow.
Logical steps of Bus conversion bapos Conversion General Discussions 12 07-28-2018 04:18 PM
Tire Tread Elliot Naess Conversion General Discussions 3 12-01-2008 06:46 PM
Using the steps as a shower Roasting8 Conversion General Discussions 2 02-14-2008 07:39 PM
Order of first steps? HickoryHusker Conversion General Discussions 6 09-04-2007 03:07 PM
Uneven tire tread wear the_experience03 Everything Else | General Skoolie Discussions 11 05-17-2007 02:58 AM
