Old 03-11-2011, 03:04 AM   #1
upping weight limit on bus
got a 88 mini blue bird school bus bread truck ish front end. 6.2 chevy dfiesel i was comparing it to my 71 gerstanslager bookmodile p-30 chassis to dodge d40? chassis and supposedly the weight limit of the antique bookmobile is about 3000 lbs more payloadc pacity then the modern breadtruck sized bus, to be expectyed, different chassises. anty way i can up the payload capacity of the blue bird short bus. does it nned to be new axles and all or just a spring pack issue or something else etc etc.
thanks
adamanderr is offline   Reply With Quote
Old 03-13-2011, 12:31 AM   #2
Re: upping weight limit on bus
nothing? come on seems like this could be a simple answer but i dont know myself. keywords for a search
Old 03-13-2011, 06:57 PM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
This cannot be done safely, short of re-engineering the bus. If you need a higher weight capacity, you need to bite the bullet and get a different vehicle.
Jarlaxle
Old 03-15-2011, 04:25 PM   #4
all id like to do is up the rear axle load by a few hundred. can i not add helper springs or a heavier spring pack.... maybe i would also need uprated axles. they do it on pickups all the time dont they
Old 07-07-2011, 09:38 PM   #5
Year: 19
Coachwork: chevy
Engine: cat c5
Rated Cap: 35
http://www.easternsurplus.net/duece_spares.html
the 5th item down that says bobber kit could be used if you or someone you know is an experienced mechanic. those leaf springs will support close to 3 ton if you have a solid rear axel
oscarsbigredball is offline   Reply With Quote
Old 07-07-2011, 09:44 PM   #6
Year: 19
Coachwork: chevy
Engine: cat c5
Rated Cap: 35
the 5th item down that says bobber kit could be used and they can support well over 5 tons each. so if you like the bus you have or only have 800 bucks for upgrade these are much better than a whole new bus.
Old 07-07-2011, 09:47 PM   #7
Year: 19
Coachwork: chevy
Engine: cat c5
Rated Cap: 35
the 5th item down that says bobber kit can be used to replace the rear leaf springs on your bus. they can support 5 or 6 ton safely and only cost 800 dollars
Old 07-08-2011, 11:20 AM   #8
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
nice link!
Overall Weight of Skoolie baadpuppy Conversion General Discussions 1 06-03-2011 07:48 PM
Actual weight of a Bus Coma Conversion General Discussions 0 08-17-2010 03:16 PM
"Limit your infinite, Young Man!" bus-ted Everything Else | General Skoolie Discussions 1 03-01-2010 05:51 PM
weight of WVO nyrockingchairs Veggie Oil | WVO | Biodiesel | SVO 1 06-02-2007 03:55 PM
Bus Weight phillip266 Everything Else | General Skoolie Discussions 3 05-26-2005 09:58 AM
