Old 08-13-2015, 08:00 AM   #21
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I will probably get a lot of bad comments for this, but, I really don't see the need for a diesel engine on a shorty. Cost a lot to buy them, cost a lot to repair them ($400 injectors, $2,000 pump, solenoids and glow plugs are usually very pricey too, Filters and oil change prices will shock you.). Sure you get a little better mileage. More torque. My 5.4 gasser pulls my trailer just fine at 65 MPH. I use my bus about 6-8 times a year and for maybe 3-4 thousand miles. Of course your needs may be different from mine. If you travel full time , then I see the need for a diesel, or maybe you tow a monster trailer. IMHO
Of course you don't want a gasser with 200,000 miles on it but mine has just over 100,000 so it should last a very long time.
Old 08-13-2015, 08:31 AM   #22
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Glad to help! Keep looking. As you look you'll be able to better understand what type of bus you're looking for. Take pictures to remind yourself about what you liked/didn't like about a particular bus to help narrow your search.
M1031
M1031A1 is offline   Reply With Quote
Old 08-13-2015, 01:28 PM   #23
NaturalStateNomad's Avatar
Chassis: Thomas
Engine: 3126b CAT
I'm in the "Ok-I got some money saved up-I'll start shopping." group that sdwarf36 was talking about and I have got to say, the process of looking for a bus has NOT been an easy one at all. There are so many subjective views out there that it's really hard to follow advice from people who have "been there, done that."
In the end, all that really matters is your goals and what you're looking for in the bus. If you're going to be traveling full time, you need a reliable engine and transmission, if the bus is going to be moved to a property and converted you may not even care if it has either!
Each person requires more or less space depending on their needs and the problem there is, there are SOOO many buses out there on the market that it is flooded with both great and bad finds.
I'm not sure where I'm going with this aside from just to say that I'm where you're at and the ride has been a long one for the past 2 months, although I do feel like I'm getting closer to finding the perfect Skoolie for us! Keep on looking until you just "feel right" about it and then go for it!
The adventures of two full-time travelers from the Natural State, living in a bus and exploring life, one road at a time.
Follow along at: www.naturalstatenomads.com
NaturalStateNomad is offline   Reply With Quote
Old 08-13-2015, 02:25 PM   #24
Engine: 190hp 5.9 Cummins
Your right, only because the $hit selection of diesel engines in shorties.
If you could get a 12 valve Cummins in a shortie, it would be cheaper to run and maintain than Any Gas Engine.
The lack of a Cummins engine in shorties is the biggest reason I will never own a shortie.
Next reason is lack of brakes, load capacity, shitty little tires that are always over loaded, ect.
Gas engines have far more parts that need changing on regular intervals than a 12 valve Cummins.
Plugs, wires, distributer cap, rotor, carb cleaning, ect.
Old 08-13-2015, 07:06 PM   #25
Engine: TE 444
Rated Cap: 12
My next bus WILL have AC, I have been pricing AC in my current bus (driving on the road AC) and so far I could buy another bus for the price of installed AC
Old 08-14-2015, 11:51 PM   #26
Lissa's Avatar
I am going to be traveling in this full time. Probably doing a combination of seasonal work, side income (selling items on etsy, etc.), and possibly working on community/organic farms through WWOOF in exchange for board and food. I want to get involved in activist projects around the country, see the national forests, meet loads of new people... really tramp all over the place for all sorts of reasons. My goal is to see every single state in the U.S. Then I'll start thinking of ways to see other countries. I want mobility and freedom for a long time. So this needs to be a very reliable travel bus. I may wind up settling down on a piece of property to homestead at some point, but that wouldn't be for quite some time.
I think that diesel really would be best for my interests. A good engine and good transmission with as little mileage as possible is an absolute priority.
Again, thank you all! I will keep searching
Lissa is offline   Reply With Quote
Old 08-15-2015, 12:35 AM   #27
If you are thinking of putting many miles on it, definitely go diesel. And shoot for as many gears as you can find as far as the tranny. 5 minimum...6 is even better. And if you can score an overdrive unit...mmmmmmm!
Also check the gear ratio and tire size before you buy or go to the site below and make a few notes. It will tell you how many rpm's you'll be turning at various speeds with the ideal being within a hundred or so of any given engines "sweet spot" at highway speed. Every engine has one and it is usually close to it's peak torque number (not HP...torque).
Engine RPM Calculator
If you can find or put together a package like described, you will be on track for optimal fuel mileage, reliability and peak longevity.
Best of luck on your quest!
Old 08-15-2015, 07:26 AM   #28
Sounds great. Hit us up if and when you get to the land of Disney.
When bus shopping it really pays to know whats out there and what to look for. Patience will pay off big time.
I was ITCHING to buy a bus... But I passed up a ton of "awesome florida buses" and bought a GOOD one from Kentucky. For some reason I'll never understand folks erroneously think FL buses are worth a lot more than a lot of other eastern states. Under-maintained buses in salty humid air...
If I were you, I'd buy a Colorado bus. Built for the mountains. Buy/build the bus for the worst terrain you'll encounter.
Old 08-15-2015, 09:40 AM   #29
Dammit's Avatar
Chassis: TC2000 RE
Engine: Cummins 8.3
Rated Cap: 78 passenger
Keep in mind that where you're buying doesn't always equal where the bus spent its life. Look at the district stickers on the side and figure out where it originated. Also, call the manufacturer with the VIN and they can usually tell you where the bus went from the dealer.
I bought my Thomas and my Bluebird from the same auction in Denver. The Thomas spent the first 13 years of its life in Maryland, but was bought and driven by a local bus contractor in Denver. It's rusted underneath pretty bad from its time back East.
The BB was bought and driven by a Colorado school district, so she was well maintained and is virtually rust free underneath. What lies under the plywood flooring may be a different story, but we shall see what we shall see. I'll know soon enough. In the meantime, she's got a big Cummins diesel, Allison with retarder, fresh tires, and screams down the road (for a bus)...
Good luck with your search!
Dammit is offline   Reply With Quote
Old 08-15-2015, 10:03 AM   #30
Lisa, you have absolutely nothing to apologize for. I'm a noob as well and will probably ask some questions that have already been asked and answered. The problem being the mobile version of the dite doesn't appear to be very friendly. But I am!! If I know the answer to your question I'll just jump right in there and click on a few keys!! No worries!
Karen is offline   Reply With Quote
