Old 11-19-2010, 05:55 PM   #1
Year: 1978
Chassis: bus
Engine: 400
Voltage regulator help!!
I just got a 78 GMC G30 shuttle bus that my friends and I are going to use to take up snowboarding, but I am having some issues. I just had the alternator refurbished, and the dudes at Napa said that I should replace the voltage regulator as well. I pulled out the plate that has two regulators, one adjustable one is not. They said that there should only be one hooked up, but they were both connected to different things. Is this correct and do they need to be replace when the alternator is refurbished? Thanks in advance for your help.
Shortbus Nixon is offline   Reply With Quote
Cautions: High Voltage Low Voltage lornaschinske Conversion Tutorials and How-to's 8 02-12-2012 02:17 AM
28 die as bus touches high-voltage wire crazycal School Bus News 5 06-15-2010 07:43 PM
air compressor and regulator maintenance 1Buck Mechanical and Drivetrains 0 03-29-2010 06:37 PM
Multi Voltage Alternator / Generator / Welder Papabear Conversion General Discussions 1 09-21-2009 01:20 PM
LP tank draws liquid is there a regulator avail to convert. JonCBrand Conversion General Discussions 7 02-09-2007 07:29 PM
