Old 08-23-2016, 04:37 PM   #1
What to do with handicap lift?
1st hello all!
Been doing a ton of reading here and some awesome conversions, as well as a ton of info.
Now me and the wife are thinking about buying a school bus to convert to a summer time RV. We have decided we would like a 7 window short bus. Or the ones with the handicap lifts as they are just short enough for the wife to drive and have enough room for 2 months of living.
Here is the problem, what to you do with the huge handicap lift?
Are they easy to remove, and if removed can you resell them?
Thanks for any advice.
Freakdylan is offline   Reply With Quote
Old 08-23-2016, 05:46 PM   #2
Originally Posted by Freakdylan View Post
1st hello all!
Somebody around here said that disabled veterans' groups really want them. Try Wounded Warriors; if they don't take it I'll bet that they know someone who will.
Old 08-23-2016, 06:24 PM   #3
Jolly Roger's Avatar
Engine: Detroit 8.2
There are some on here that are building there rear half for toy haulers and I remember someone asking for a lift in the last week or two for a lift to pick up there motorcycle or something so yes between wounded warrior projects(there are a lot of veteran aid programs out there that need assistance) but you can post it in the classifieds on this site also.
I don't think you would have many problems getting rid of it.
Old 08-23-2016, 06:44 PM   #4
Thanks for info will try those routes once we get the shorty.
Has anyone ever removed one before? Just curious if is as hard as it looks, with hydraulics and the weight.
Old 08-23-2016, 07:05 PM   #5
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
My lift is 1 window from the front by-fold door so it will effect the living space. I was thinking of maybe making a movable cook center. Sorta indoor / outdoor kitchen. It can also be used as a lift when cook center is moved out of the way.
Tootalltechie is offline   Reply With Quote
Old 08-23-2016, 07:56 PM   #6
CaptainHooligan's Avatar
What's your location, I'm kinda looking for one. Kinda.
CaptainHooligan is offline   Reply With Quote
Old 08-23-2016, 10:44 PM   #7
roach711's Avatar
Rated Cap: 19
Removing mine wasn't very hard. I removed the bolts at the front of the lift that would be covered by the lift when it was extended then let the lift down on a flat bed cart so I could move it by myself once it was loose. After that I removed the bolts at the back of the lift and used a pry bar to shove it out the door. I put it on Craig's list for a month or so without so much as a nibble. Eventually it got sent to the scrap yard.
The Roach Motel
Old 08-23-2016, 10:47 PM   #8
Engine: t444e
I'm making mine into a foldout bathroom with a popup tent of some sort for privacy. The poopdeck.
ChiliChzPoopTart is offline   Reply With Quote
Old 08-24-2016, 12:31 AM   #9
Coachwork: Startrans
Chassis: E-350 super duty
Engine: 7.3 L powerstroke Diesel
I just removed mine, it got to where it would not go back up and i said screw it, need the rear space more then the lift. since mine was already stuck in the down position, I removed the pivot pin bolts and used vise grips to work the pins out, removed the arms and cylinders off the main frame after disconnecting the lines, this took about 2 hours by my self. make sure to disconnect the main power wire first. then tonight I removed the main mounting plate, ( 8 bolts ) I used an electric impact gun from underneath and vise grips holding the top bolts. took about 30 minutes. just beware these things are very very heavy. mine tried to come down on me the first time I opened the door. if it starts to come down, jump out of the way, you will not be able to lift the weight.
hope this helps ya some.
Hoverlover is offline   Reply With Quote
Old 08-25-2016, 09:20 AM   #10
Thanks all! You have answered my questions, now me and wife can go look for our dream bus.
