Old 02-17-2015, 09:21 PM   #1
where to buy parts
i have a 2001 ford E450 where can i buy reg parts advance auto parts dont list the E450.
fnelson71 is offline   Reply With Quote
Old 02-17-2015, 09:32 PM   #2
or is there a parts interchange
Old 02-18-2015, 06:48 AM   #3
Coachwork: ward
Chassis: international
Engine: dt360a
i have had good luck using oreillys for larger truck stuff. they even had brake calipers for my international bus and the price wass great!
Old 02-21-2015, 12:50 PM   #4
or try Napa auto parts
Old 02-21-2015, 04:46 PM   #5
roach711's Avatar
Rated Cap: 19
If you're just buying engine parts, the E-350 and E-450 parts are the same. Brakes, shocks and springs will likely be different between the two. Ford either has or can order whatever you need.
Old 02-21-2015, 08:00 PM   #6
roach are the rotors the same as the e350
Old 02-21-2015, 08:33 PM   #7
Rated Cap: 40 Prisoners
Bus parts
You might check your local area for a Fleet Pride store they usually carry parts for medium to heavy duty trucks and buses my last serpentine belt I got from them was a better belt than I could of gotten from NAPA and for less money.
Old 02-22-2015, 03:45 PM   #8
roach711's Avatar
Rated Cap: 19
O'reilly Auto parts lists both the E-350 and E-450 parts and it appears that the front rotors are different between the two models.
Old 02-22-2015, 09:08 PM   #9
what is that huge battery behind the door on the pass side? and what size is it.
Old 02-23-2015, 01:28 PM   #10
roach711's Avatar
Rated Cap: 19
I'm assuming it's your starting battery. Pictures of your rig would help immensely.
Old 02-23-2015, 01:30 PM   #11
I posted it. As here's what I'm working with
Old 02-23-2015, 05:42 PM   #12
Old 02-23-2015, 06:13 PM   #13
roach711's Avatar
Rated Cap: 19
Yup, that's your battery for starting, running the AC fans, lights and wheelchair lift. It may be an 8D size (20 3/4 x 11 x 11").
Old 02-23-2015, 07:02 PM   #14
i cant find any info on it so here is a better pic where can i get one and whats the best battery to get.
