Old 02-10-2019, 06:42 PM   #21
firebuild's Avatar
Coachwork: Lewis
Engine: Ford E350 7.3L Diesel
OK, I just came across this:
ANSI A119.2/NFPA 1192 STANDARD ON RECREATIONAL VEHICLES (1999 Edition)
2-2.3 Location of LP-Gas Containers. LP-Gas containers shall be in accordance with the following:
(a) LP-Gas containers shall not be installed nor shall provisions be made for installing or storing any LP-Gas containers, even temporarily, inside any recreational vehicle. Containers shall not be mounted on the exterior of the rear wall or the rear bumper of the vehicle.
So.... no mounting them to the back.... at all? That seems weird. Where else are you gonna put them, if you can't put them inside and the whole rear wall is off limits? Makes no sense whatsoever to mount them on the side, that seems even more unsafe. I understand why no bumper, but nowhere on the back wall??
There would be no way to mount a standard tank underneath my bus, it would have to be a horizontal and those are expensive. I'm not even sure there would be room horizontally.
firebuild is offline   Reply With Quote
Old 02-10-2019, 06:56 PM   #22
You'll always see the propane bottles mounted on the fronts of RV trailers. Rear crash impact is why they can't be located on the back.Unfortunately, to be perfectly legal, may mean spending some extra money and not using the cheap out.
Old 02-10-2019, 08:05 PM   #23
firebuild's Avatar
Coachwork: Lewis
This is one of those selective safety situations that drive me nuts.
If I'm in a collision, and I'm the REAR vehicle, then a front-mounted tank is basically the same as a rear-mounted tank. So I just don't get that. The theory behind this is that it's only going to explode if I get hit, not if I hit someone? And what about head-on collision? It just seems like these rules are somewhat arbitrary and don't make a whole lot of sense. I mean, I understand the bumper, but the REAR WALL of the vehicle? I'd have to be hit from behind by an 18-wheeler for propane halfway up the wall to be impacted.
Then there's the fact that propane tanks almost never explode. I remember seeing a Mythbusters episode where they try like hell to get one to blow up, and it takes actual explosives to do it.
If you're in a vehicle that catches fire from the GASOLINE (which is orders of magnitude more flammable than propane), the heat from the fire might cause it to explode, but there's no way it would be the CAUSE of the fire. It's just not volatile enough, and even if the tank ruptures (which is extremely unlikely), it puts out a gas that is flammable, but it doesn't ignite itself. And the odds of a rear end collision causing a gasoline fire are pretty slim.
Four or five years ago a propane tank on the back of a food truck randomly exploded, but it had nothing to do with a collision and it would not have mattered where the tank was: it was improperly filled by UHaul (I'm guessing they overfilled it). 2 people died in that accident, but again, there was no collision or anything involved. There have been other food truck related explosions, too, but it's tossing a match into a leak that causes the explosion every time, not impact. These are the kinds of propane-related accidents that make the news, NOT rear end collisions that result in vehicle explosions.
I grew up in a super fire-conscious household; my Dad, Uncle, and Grandpa were all firefighters. Again, I understand not sticking it right in the line of someone's bumper, but the idea that it's too dangerous to go on the wall is really strange.
OK, rant over. I guess I won't do this, either, but it's not because i'm afraid of an explosion: it's because I'm afraid of a ticket.
Old 02-10-2019, 08:15 PM   #24
Propane is another fuel source, on an RV it should be mounted the same as a fuel tank, outside and under the vehicle. Anyone know of any RV where they put them elsewhere?
Old 02-10-2019, 08:19 PM   #25
Sleddgracer's Avatar
Chassis: still looking for my bus
I've witnessed both, fire from gasoline and fire from propane - the gasoline fire happened as a result of a rear end collision, on an old one way wooden bridge - the families in both vehicles were able to escape to either end of the bridge - the creosoot in the bridge caught fire and burned the entire bridge down - the propane fire was likely caused by the valve not being closed properly, or perhaps opening as it rubbed against something else in the loaded pickup - the guy was moving all his possessions, he claimed, when the fire started as he drove down the road - he was able to escape the flames as they shot many feet into the air - we stood talking as we watched everything burn - a couple of hours later, when everything had been hosed down and cooled off, he was able to start the blackened truck and he said he was taking the truck and all to the dump -lol
Old 02-11-2019, 02:30 AM   #26
firebuild's Avatar
Coachwork: Lewis
As has been mentioned, some RVs mount them on the front, not under the vehicle, plus there are tank holders specifically designed to ride on trailer hitches. I've seen dozens and dozens of Jeeps riding around with easily-punctured jerry cans of gasoline in legal, approved carry racks on the back. Gasoline can ignite at temperatures as low as 80 degrees. It takes almost a thousand to set propane alight. So why is propane the dangerous one? And propane accidents, which are literally almost never related to impact or tank puncture, are no more likely to happen on the back of a vehicle than anywhere else. I'm not saying propane poses no risks, but we're allowed to do all sorts of risky, stupid things. This one isn't even really risky when you compare it.
Personally, I would feel more safe with my tank easily visible on the back than under the bus. It seems to me I'm more likely to avoid the true risk of driving with propane - not properly closing a valve - if the tank is within easy eyesight than if I have to get down on all 4s to see it.
Old 02-11-2019, 02:40 AM   #27
firebuild's Avatar
Coachwork: Lewis
Yeah, that's my point - it's got nothing to do with where the tank is. It's got to do with a valve issue or over pressurization. Again, I'm not saying there's no risk, just that me mounting my propane on the middle rear of the bus is not increasing that risk.
Old 02-11-2019, 07:39 AM   #28
Yukon Cornelius's Avatar
Another thing to think about other than tunnels and parks is Ferries, they have some down right ridiculous rules about TDG, propane and gas are of them. Visible tanks either propane or gas will get you more attention than you want.
typically speaking most boats won't let you have more than 1x 30lb tank or 1x 20L gas can...... These rots me as 9 times out of ten after having this argument, they park you on the boat right beside a b train tanker.....with you guessed it 1203 or 1978 on its placards...
Underneath in a cage with adequate ventilation and ground clearance would be my recommendation, safe, secure and out of site.
Yukon
Handyman and Shenaniganizer
http://www.skoolie.net/forums/f11/97...ion-22324.html
Yukon Cornelius is offline   Reply With Quote
Old 02-11-2019, 02:36 PM   #29
firebuild's Avatar
Coachwork: Lewis
It's not that I have an objection to putting it underneath; I just don't see where it would go. It's a shallow space, and there's already two fuel tanks under there. Ground clearance is a concern, also.
Old 02-11-2019, 02:54 PM   #30
farok's Avatar
Engine: 6.0L Gasser
That's why -- as much as I would prefer 20lb tanks -- I'm looking hard at the little 5lb tanks. They're about 12" tall instead of the 18" of a standard BBQ cylinder. They're also 8" diameter instead of 12". Unfortunately they run out much quicker as well...
My build thread: http://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
