Old 12-01-2016, 11:50 PM   #1
Which Shorty to buy in Canada?
Hello all,
Long-time vehicle builder, 1st time looking into a bus project. I am going to be buying a "short-bus" very soon, for all the group road trips my friends and I take (hunting, fishing, etc..). I have $6,000CDN to spend, which seems to make things more complex because I am seeing lot more options than I expected to find. I know for a fact I want a diesel engine..so I started reading the forum and there is just sooooo much information, so many models and so many conflicting opinions; I thought I would post a thread instead. I am after two main things, the most reliable engine/trans combo and the best possible fuel economy, towing capacity is not so much of a concern, heaviest thing I'll pull is a tin fishing boat..I am not opposed to making necessary modifications to increase MPG and will be gutting the interior regardless. I am not married to any specific brand. 90% of the time this vehicle will be hwy driven for long journeys (500-750km +), primarily driven in the spring through late fall, needs to accommodate seating and gear for 10 people. If it was your money..what do you buy and why? Thanks all...
BN
Boostnut is offline   Reply With Quote
Old 12-02-2016, 01:18 AM   #2
Coachwork: Corbeil - RAMROD
Chassis: IH 3800 66 Pass
Engine: 7.3 IH IDI NA w AT545 hyd
Hey BN,
Where in Canada? I haven't checked Kijiji in a while but that is where I found my bus. Most of them are overpriced so you really have to be picky, at least in AB from when I was looking.
If you gather a couple of options - I can help with suggesting which ones would be best for you and save you some time.
slidewayzm5 is offline   Reply With Quote
Old 12-02-2016, 02:02 AM   #3
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Here in BC there is a few busses for sale. 1 even done up here in Prince George BC.
Tootalltechie is offline   Reply With Quote
Old 12-02-2016, 07:59 AM   #4
I am located in Toronto..no issue traveling within the province for the right unit.
BN
Old 12-02-2016, 08:03 AM   #5
Year: 1974
Rated Cap: 48
No problem good luck with the search.
Gordon
Old 12-02-2016, 08:05 AM   #6
I have found a used mini bus dealer offering the following. Mini buses for 19 people with T444E V8 diesel in the Ford E-350 model & a 6.5L V8 in the Chev 3500 series model. Both have auto trani’s with over drive and are single rear wheel chassis. Also, wheel chair units with the T444E V8 diesel, Fords auto with over drive, body painted white with dark windows and a wheel chair lift in the front right corner and are a dual rear wheel chassis. All 2002-2005 units and the same price. Thoughts?
Old 12-02-2016, 11:30 PM   #7
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Personally, I would prefer a dual-wheel bus, no-matter how small.
First off, you end up with two "spare" tires in case of an emergency.
Second off, stuff gets heavy fast.
I would go for the ford, the international engine is better than the chev.
Literally every Chevrolet vehicle I have driven has broken down...
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 12-02-2016, 11:45 PM   #8
Carytowncat's Avatar
Welcome! Glad you're here. Good luck with your search. It seems the right bus has a way of finding us
Old 12-03-2016, 12:13 PM   #9
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Originally Posted by Boostnut View Post
I have found a used mini bus dealer offering the following. Mini buses for 19 people with T444E V8 diesel in the Ford E-350 model & a 6.5L V8 in the Chev 3500 series model. Both have auto traniís with over drive and are single rear wheel chassis. Also, wheel chair units with the T444E V8 diesel, Fords auto with over drive, body painted white with dark windows and a wheel chair lift in the front right corner and are a dual rear wheel chassis. All 2002-2005 units and the same price. Thoughts?
Have you tried an actual bus company? That's where I got mine, just east of Guelph. They only have long buses and coaches....but there are other bus companies out there. Picked it up for 2 grand.
As you will already know, Ontario loves there salt in the winter time and finding a decent bus after it's expiry date will be tough.
Old 12-03-2016, 12:15 PM   #10
Great point about the weight and spare tires...seems many are dual wheeled that I am seeing. Any fuel mileage differences between the engines?
